17mb62 Turning its self on :O
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hello, I have a small 19" luxor vestel built tv that seems to turn its self on in the early hours in morning when its cold. Just wandering where to check is it software or hardware, will take photos on may even set a camera up in the night to film it lol ?
  • vinceroger69
    • Mar 2012
    • 6714
    Re: 17mb62 Turning its self on :O
    I had a toshiba set once doing this it turned out it was doing freeview update scans during the early hours i turned this setting to off it never happened again.
    • newtothis
      • Mar 2013
      • 1556
      • england
      The issue = It's Vestel! LOL
      Set goes cold, ESR of a cap goes low enough and turns set on maybe?
      Had a look at the boards yet?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I was think that as well esr goes up with cold temps, it is in the coldest room in the house it uses craps any way. Mares well switch it off at the wall lol the stupid thing
        • CapLeaker
          Leaking Member
          • 8193
          It's the other way around. Heat makes the ESR go low. Cold makes the ESR go higher.
          • newtothis
            • Mar 2013
            • 1556
            • england
            < Is not with it today! Sleepless night if you check my posts
            • CapLeaker
              Leaking Member
              • 8193
              You shall be forgiven...
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Decided im going to recap the psu, as it has samxon km prone to failure with out physical signs if not recap the main board hopefully stop this thing from turning on at 3am lol scares the crap out of everyone becuase the volume always starts boombing loud.
                • CapLeaker
                  Leaking Member
                  • 8193
                  Think about it for a minute. The PSU needs a PSon signal from the main board in order to turn on. The PSU can't turn on without that PSon signal and that comes from the main board. Plus I would disable the IR port first and see if that helps any. Put some black electrical tape over it etc.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Will do cheers got to love vestel sets
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      does it alaways turn on about 3am? whats the full model number of the set?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Yes is always when the house is at its coldest thats why I think caps.
                        I will open up the set and take photos, I need to get cap values anyway.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Freeview updates taking place at 3.00am....
                          I'll bet its 3.00am its happening......
                          Turn off the update feature in the Settings menu.
                          LOTS of sets do it, you'll hear the relay in the PSU operate then 1 minute later again. I have a Pioneer that does it but the set remains dark during the process.
                          Vestel obviously didn't bother making sure the set remained dark--so it fires up fully!
                          TELEFIX
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            I think your on to something I always thought it was 5am will check now thank you
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              I did mention this also in post 2 i have i have saw this a couple of times now my toshiba set defently turned fully on during the early hours and im sure the other was a alba? both vestel main boards.
                              • JeffJ
                                • Apr 2012
                                • 189
                                I had a woman drop off an almost brand new Toshiba TV at my work for recycling. she said she didn't want it she bought a new one. I said well I bet I can fix it for you at a low cost. She said nope, I want it out of my house it's haunted.... Turns out it turned it self on at exactly 3 AM as well. I just factory reset it. and it seems fine though. Still have it in my shop.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Fixed the issue, simply by turning the freeview update off I also recapped the psu as well thanks for the help guys I alway thought that freeview update was at 5am. Anyhow turning it off has solved the issue the tv hasn't done it since
                                  • valvelover
                                    • Nov 2017
                                    • 6
                                    my samsung plasma used to do this ! used to freak me out ! you cant sleep so you go down to make a brew, your sitting in the dark.........and the tv turns on ! screen just glows............then turns off again ??? thought it was the other side trying to contact me ! ............but no.......it was the freeview updates !
                                    • Askic
                                      Hitachi (Vestel) TV is not turning on
                                      by Askic
                                      Hello guys,
                                      I have 32 inch Hitachi TV with Vestel PSU board 17IPS71. Tv was working normally and I shut it down normally via remote control.
                                      The next morning it couldn't turn ON neither with remote controller or via button on the logic board.
                                      There is a red standby LED ON, so it is not dead totally.
                                      I have examined the PSU board and I cannot find find any traces of blown components or bulged caps. Electrolytic caps are manufactured by Elite.
                                      I also check diodes and big MOSFET (with cooler/heatsink). It seems OK.
                                      Can you tell me based on...
                                      01-11-2023, 12:34 PM
                                    • France_53
                                      Vestel tv, how to flip the image?
                                      by France_53
                                      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                      05-12-2024, 05:22 AM
                                    • FlailingEngineer
                                      Help with Bush Tv (Vestel 17mb95m Mainboard)
                                      by FlailingEngineer
                                      Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                      Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                      05-31-2023, 06:52 AM
                                    • loadedboyuk
                                      Vestel / Luxor TV 50 inch UK Not reseting
                                      by loadedboyuk
                                      Hi people,
                                      I have not posted in a while glad to see the forum is still going strong
                                      I ahve a 50 inch luxor branded TV, it works well but it will not let me reset / return and store the updated TV channels.
                                      it works fine while powered on BUT...
                                      Every time I switch it off (stand by or mains) the channel lists reverts back to the old channel listings.
                                      I have reset it multiple times, tried to reset via the engineers menu, ran to see if any updates are alavilbe over the internet.
                                      its about 2 years old and "smart"...
                                      05-23-2020, 03:01 PM
                                    • massimomax
                                      Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                      by massimomax
                                      Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                      spero che qualcuno può averlo per riprogrammare eprom. grazie
                                      Post in English !!!
                                      I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                      02-28-2025, 07:27 AM
