Dynex LCD TV DX-32E150A11 Won't turn on
  • Tekone
    • 79
    • united States
    Hi, my friend gave me his TV because he couldn't get it to turn on, when the power cord is plugged in the red standby light comes on but wont turn on.
    I took it apart to check for bad cap but didn't see any.
    Can someone please help out with this I have attach some pictures of the power and main board.
  • CapLeaker
    Leaking Member
    • 8352
    Re: Dynex LCD TV DX-32E150A11 Won't turn on
    turn on the tv and probe the PSon pin on the power supply.
    • Tekone
      • 79
      • united States
      how do I do that and whats the pson
      • Tekone
        • 79
        • united States
        The TV doesn't turn on.
        • Tekone
          • 79
          • united States
          Okay with the power cord plugged in and the standby red light on from the PSon pin on the cn2 connector I'm not getting any voltage.
          • CapLeaker
            Leaking Member
            • 8352
            Got a bad main board. It's not turning the power supply on. You can test this by forcing the power supply on without the main board.
            Unhook all the main board cables from the power supply. Take two 1k ohm resistors and jumper 5V STBY to PSon, take the other resistor and jumper BLon (LCDon) to 5V. Plug in the power supply and all the voltage rails on the power supply should be up and running.
            • Tekone
              • 79
              • united States
              Thanks for your help. I don't have any resistors, is there another way to do the test?
              • CapLeaker
                Leaking Member
                • 8352
                I suppose you could, but also you run into a higher risk of damage. I don't condone it.
                  • 12331
                  • U.S.
                  try unplug the mainboard from power supply, turn on tv, see if backlights come on, I believe they will IF it has pull up resistors.
                  • Tekone
                    • 79
                    • united States
                    Can I use one the standby 5v to jump LCD on
                    • Tekone
                      • 79
                      • united States
                      No did not turn on the backlight
                        You need the resistors to force on the PS0N, BLON, the resistors are for limiting current in case you slip or hook up to the wrong location, also in case the receiving pins do not have built-in current limiting resistors.
                        The resistor can be from 1K~500 Ohm.
                        • Tekone
                          • 79
                          • united States
                          Okay so I disconnect the main board and ps on to sb, lcdon to 5v on got the backlight to come on
                          • Tekone
                            • 79
                            • united States
                            I disconnect main board jump ps on to stand by 5v and jump lcd on to 5v got the backlight to come on.
                            What's next to try?
                              So you will need main board since you are able to force on the backlights.
                              • Tekone
                                • 79
                                • united States
                                Okay thanks very much for your help
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • RdeveLabs
                                  MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                  by RdeveLabs
                                  To all the members here...
                                  Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                  So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                  05-05-2025, 04:59 AM
                                • robante15
                                  Acer Aspire 4520 won't turn on after reboot
                                  by robante15
                                  Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                  It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                  The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                  If I remove the...
                                  04-06-2024, 06:50 PM
                                • masoksian
                                  Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                  by masoksian
                                  I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                  The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                  The system does not turn on, there is no post.
                                  I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                  The problem continues in the same way.
                                  I tried to turn on the Fn key, nothing came to the screen....
                                  02-15-2025, 12:08 PM
                                • Ledgurra
                                  MacBook Pro A1425 it doesn't turn on
                                  by Ledgurra
                                  hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                                  thank you all
                                  11-09-2025, 06:07 AM
