magnavox 37mf321d/37 burned power supply
  • Agent24
    I see dead caps
    • Oct 2007
    • 5035
    • New Zealand
    Re: magnavox 37mf321d/37 burned power supply
    You could get the datasheet for it and then try to find something with matching specifications...
    http://www.st.com/web/en/catalog/sen...chtype=keyword
    -David VanHorn
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Thanks for the reply Agent24. The only thing I could find online was alternate from Digikey for 2,000 units for $1,324.00 or ebay from China, two for about 8 bucks. So I will go for cheap. The TV is old and not worth it. Just can't give up and it will make a good garage TV, if not I am not out that much. Will update post when I get the part. Just hoping someone found something compatible.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5035
        • New Zealand
        Ones from China will likely be OK if the seller is good. Otherwise you may risk fakes. Read feedback carefully. Search for previous sales of the same part if you can. http://www.feedbackselector.com/ works well unless the seller has been using 'private' listings.
        -David VanHorn
        • whiz62
          whiz62
          • Dec 2013
          • 242
          • usa
          Thanks for the info Agent24. Will check it out.
          • whiz62
            whiz62
            • Dec 2013
            • 242
            • usa
            I found a two pack on the mosfet at location 7071 from ebay part# p45nf3ll and also got an axial diode and resistor and scraped past the burn spot and soldered on and now have steady power led on front panel. But I don't have backlights but do have the 24 volts going to inverter board and fuses are good.
            Looks like there is a slave inverter? got another two wire connector going to other side of panel and disappears under shell. Looks like a complete dis assembly. oh boy! These older tv's gotta lot of honking metal and screws!
            Think I will let this rest a day or two. Thanks all for the help
              OK do you have BL-ON and DIM control signals to the Inveter also?
              • whiz62
                whiz62
                • Dec 2013
                • 242
                • usa
                #27
                Only other two connectors with wires are pin 12 bl-on= 0.02 volts and pin 13 e_pwm=3.2 volts. Looks like I still got a problem else where. Thanks all other info appreciated.
                  Main board is not sending out the BL-ON, you can force it on to see if you can get normal pictures on the screen using 1K between BL-ON and the 5VSTBY, BUT YOU MUST remove or cut the BL-ON wire going back to the main board FIRST!
                  • whiz62
                    whiz62
                    • Dec 2013
                    • 242
                    • usa
                    #29
                    Thanks budm! Will try that in the morning and post results.
                    • whiz62
                      whiz62
                      • Dec 2013
                      • 242
                      • usa
                      #30
                      Well, I dug into this and and found pin #9 on connector 1089 is where the 5vsbt is supposed to be but it isn't there. I was mistaken before and got in a hurry. Went to budm school for awhile today and that has helped. So I assume this is why I don't have back light.
                      here are readings on connector with all plugged but tcon:
                      1. 16v..reads w/ pwr button not on=18.50v..w/ pwr button on=18.50
                      2. 16v..reads w/ pwr button not on=18.50v..w/ pwr button on=18.50
                      3. bright adj.=0v&0v
                      4. inverter on/off w/ pwr button off= .05v.. w/ power on= 3.24V
                      5. F027 w/pwr button off=4.25v..w/pwr on= 4.77v
                      6. 0
                      7. 0
                      8. 0
                      9. standby..w/pwr button off=.01v..w/pwr on=1.24
                      10. 0
                      With main disconnected, only difference is pin 4 I get 3.06v and pin 9 is 0.
                      Still trying to figure this out. Thanks
                        "4. inverter on/off w/ pwr button off= .05v.. w/ power on= 3.24V" That is good, you do have bl-on signal.
                        "9. standby..w/pwr button off=.01v..w/pwr on=1.24" Since you do have 24VDC for the inverter, then this ps-on is OK.
                        "3. bright adj.=0v&0v" This one is bad, try removing this wire and see if you will get backlights.
                        • whiz62
                          whiz62
                          • Dec 2013
                          • 242
                          • usa
                          #32
                          Will do! Thanks so much.
                          • whiz62
                            whiz62
                            • Dec 2013
                            • 242
                            • usa
                            #33
                            just disabled pin 3 wire and no backlight and no power led on front of tv when button pushed.
                              That is the dimming control signal only so it should not affect anything else.
                              Do you still have standby Voltage?
                              • whiz62
                                whiz62
                                • Dec 2013
                                • 242
                                • usa
                                #35
                                standby is 0.10 with or without power button.
                                  So now you also lost the PS-ON signal.
                                  Is the standby power supply still working?
                                  • whiz62
                                    whiz62
                                    • Dec 2013
                                    • 242
                                    • usa
                                    #37
                                    still have pins 1&2 volts of 18.5v and 4.25v to pin 5, but nothing to inverter board. gonna give it a rest till tomorrow. Thanks budm!
                                    • Tynan Dill
                                      by Tynan Dill
                                      Assuming...
                                      11-22-2024, 01:46 PM
                                      03-31-2024, 02:12 PM
                                      07-01-2024, 06:34 AM
                                    • maces
                                      SAMSUNG PS60E6500 Power Supply BN44-00513A defect and burned
                                      by maces
                                      I have a problem with the power supply of my Samsung PS60E6500.
                                      The LED of the TV is blinking and it doesn't turn on.
                                      After checking the power supply I noticed that the PCB board is burned at QP804 (K13A60D), the MOSFET is shorted.
                                      RP812 is also defect. Unfortunately the resistor is burned so I cannot read the value. Also QP805 and QP806 are shorted. Does anybody have a schematic diagram or does anybody know the type of the parts?...
                                      03-13-2023, 03:50 PM
                                    • shamsudeen
                                      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                      by shamsudeen
                                      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                      i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                      07-19-2025, 07:14 AM
