Sony KDL-55W905A blink code
  • PowerAmpFreak
    • 977
    • Sweden
    Hello
    Tried to find the meaning of those three blinks. Cannot locate any tech docs for this model.
    It's a Sony KDL-55W905A blinks in a sequence of three blinks and pause.
    PSU "seems" to generate the correct voltages, the most obvious are there though.
    Two pics attached.
    Any advice is appreciated!
  • anmol
    • Mar 2012
    • 73
    • India
    Re: Sony KDL-55W905A blink code
    Pls. post clear photo both side of each pcb.
    check with this chart, if you have same board.
    wbr
      • 12088
      • U.S.
      a bit about overheating of the w series. https://answers.yahoo.com/question/i...9051004AAwVs6w
        • 12088
        • U.S.
        some more, could be an audio issue. 3 BLINKS
        The first thing to check when a 3X blink protection mode occurs is the physical condition of the speakers and speaker connections. The speakers should measure 8 ohms. Shorted speakers or connections can cause a 3X blink protection mode.
        If the speakers and connections check okay, then the defective component is on the main board. Either an open F4200, defective DC regulator or defective audio amplifier will cause a 3X blink protection mode which would require replacing the main board.
        A defect on the Power Supply Board may also cause a 3X blink protection mode and shut-off. Check the AU12V level at CN6704/pin 14. If 0V is measure before shut-off the power supply board needs to be replaced.
          • 12088
          • U.S.
          https://cdn.badcaps-static.com/pdfs/...2fac704e9b.pdf
          • PowerAmpFreak
            • 977
            • Sweden
            Thanx for advice, will dig deeper into this and let you know my findings!
            • PowerAmpFreak
              • 977
              • Sweden
              wbr
              This guide points towards a defective mainboard.
              • RJARRRPCGP
                • Jul 2004
                • 6303
                Random DNS error. But fine now.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                  That PDF is for CRT TV: they are old info, not for LCD TV!
                  "FOUR Blinks
                  No Vert. Deflection (V STOP), Screen goes to a single
                  horizontal
                  line then the video signal muted. Check IC1509, Q1505"
                  SIX Blinks
                  No Horizontal (H STOP), no raster, goes to the blinking self
                  diagnosis function immediately. Check C515
                  & 516 and the jungle IC, IC206.
                  SEVEN Blinks
                  High voltage shutdown. The high voltage has exceeded 33k
                  and the unit goes immediately into safety shutdown. Check power supply
                  regulation and horizontal circuits.
                    wbr
                    Do you have the link to download the full service manual for this model?
                    Elektrotanya does not have this one.
                    • PowerAmpFreak
                      • 977
                      • Sweden
                      Hello
                      I ordered a brand new mainboard for this one.
                      When starting up the blinking goes between green and yellow constantly.
                      I suspect it might need a FW download, probably through USB.
                      Anyone know if this is correct and how I do this?
                      • PowerAmpFreak
                        • 977
                        • Sweden
                        According to Anmol's troubleshooting chart (post #2) a blinking green led is most likely defective LCD panel.....
                        Measuring the VLED output, it goes from +39V in standby to only +43V when on. I would assume a higher voltage.
                        The e-lyte for Vled is 100V 100uF.
                        The +43V is there even if disconnecting led panel.
                        • PowerAmpFreak
                          • 977
                          • Sweden
                          Anyone have access to service manual for Sony KDL-55W905A ?
                          I certainly need it badly!!
                          Thanx in advance!
                          • anmol
                            • Mar 2012
                            • 73
                            • India
                            Originally posted by PowerAmpFreak
                            Hello
                            You have update FW ?
                            Try first update FW with USB,
                            WBR
                            • anmol
                              • Mar 2012
                              • 73
                              • India
                              Sorry for late reply.
                              i have Sony chasis RB1G manual
                              MODEL LIST
                              THIS SERVICE MANUAL CONTAINS COMMON INFORMATION FOR BELOW REGIONS AND MODELS:
                              REGION
                              ASIA CHINA AMERICA JAPAN EUROPE ASIA CHINA AMERICA JAPAN EUROPE
                              MODEL
                              KDL-42W800A KDL-47W800A KDL-55W800A
                              KDL -42W801A KDL -47W801A KDL - 55W801A KDL -42W801A KDL -47W801A KDL - 55W801A
                              KDL-42W802A KDL-47W802A KDL-55W802A
                              KDL-42W804A KDL-47W804A KDL-55W804A
                              KDL-42W805A KDL-47W805A KDL-55W805A
                              KDL-42W807A KDL-47W807A KDL-55W806A
                              KDL-42W808A KDL-47W808A KDL-55W807A
                              KDL-42W809A KDL-47W809A KDL-55W808A
                              KDL 55W809 A KDL - 55W809 A
                              Not Schematic.
                              Size is 57,8 MB
                              wbr
                              • PowerAmpFreak
                                • 977
                                • Sweden
                                WBR
                                I tried to update FW through USB stick. It does not respond.
                                Not any sign of updating whatsoever.
                                Led blink green / orange continously in an endless loop.
                                The backlight is briefly turned on when power up, but shuts down after half a second.
                                • PowerAmpFreak
                                  • 977
                                  • Sweden
                                  According to service manual:
                                  Error of panel ID Off Green Blinking Orange
                                  Blinking
                                  Blinking:0.5sec On / 0.5sec
                                  ...indicates a state of Error of panel ID. So what next?
                                  Where are the panel ID stored? T-CON?
                                  • anmol
                                    • Mar 2012
                                    • 73
                                    • India
                                    your new mainboard is same code ? i think this is MB problem. bcoz your mb dosn't update with usb. when we replace mb it need to update.
                                    wbr
                                    • PowerAmpFreak
                                      • 977
                                      • Sweden
                                      OK. So how will I update then?
                                      • PowerAmpFreak
                                        • 977
                                        • Sweden
                                        Anmol, I did succeed to enter service menu according to instructions on page 214 (SM)
                                        I also did a picture test of different bars and colours and it all looks OK.
                                        On page 216 the behaviour is described, frontled is blinking green / amber.
                                        It is smart core waiting for USB with software. Here nothing happens.
                                        The software on the USB stick is the one I found on Sony website, but I do not know if it requires some bootloader before the main application FW can be written?
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
                                          LCD LED TV Service Menu Codes
                                          ALL LCD LED TV SERVICE MENU CODES
                                          Service Menu Code with Board Name
                                          China Universal Board / Jumper Board Service Menu Code
                                          Changhong Ruba Service Menu Code
                                          Ecostar LED TV Service Menu Code
                                          Orient LED TV Service Menu Code
                                          Haier LED TV Service Menu Code
                                          TCL LED TV Service Menu Code
                                          Samsung LED TV Service Menu Code
                                          LG LED TV Service Menu Code
                                          Videocon LED TV Service Menu Code
                                          Supra LED TV Service Menu Code
                                          Toshiba LED TV Service Menu Code
                                          Symphony LED TV Service Menu Code
                                          Veste/ LED TV Service Menu Code...
                                          10-31-2024, 03:58 AM
                                        • Storyteller12
                                          Sony XBR-65X900E 4 Blink Code
                                          by Storyteller12
                                          I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                          I don't work on Sony much but assumed it was backlights from what I read.
                                          Opened up the TV and tested all the backlights with led tester and the all work.
                                          I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                          So anyway to test these lights similar to the way we test...
                                          12-31-2022, 02:17 PM
                                        • rmacintosh
                                          Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                          by rmacintosh
                                          I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                          The symptoms of the tv ar as follows:
                                          • Plug AC in to back of TV
                                          • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                          • The 3 blink code is given by the power LED
                                          • If the TV is unplugged and then
                                          03-14-2020, 12:24 AM
                                        • AK_777
                                          Sony KD-65A1 Repair – 4 Red Blinks Error
                                          by AK_777
                                          Hi everyone!
                                          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                          02-20-2025, 04:15 PM
