Lg 42ln543v bar in screen
  • redriddick
    • 93
    • Ireland
    H Guys,
    I have an lg tv with a black bar through the middle of the screen as per attached image.
    Is this the screen or tcon issue???
    Thanks a mill
    • 12210
    • U.S.
    Re: Lg 42ln543v bar in screen
    could be, did you try reseating your tcon cable and ribbons? careful with the ribbons, use fingernail to pop up retainers, can check youtube tcon replace for a video, if you like.
    • redriddick
      • 93
      • Ireland
      Have'nt tried much as of yet??
      Will need to take apart and see what the story is.
      Still have my hands full with the philips I have in the other thread!!!!!
      • cliff_hootarski
        • Jul 2006
        • 411
        Look closely at the bottom of the black bar, it looks like an impact point.
          • 12210
          • U.S.
          go ahead n bump it, I'll take a look.
            • 12210
            • U.S.
            can't tell pic. is a little to small too see cleaerly.
              Definitely looks cracked to me... that can't be anything but impact damage. Unrepairable.
              • redriddick
                • 93
                • Ireland
                Yes the screen is in bits alright.Will scrap it and remove working parts>
                Sorry for the bother guys..
                  • 12210
                  • U.S.
                  no problem at all, at least there was a conclusion, too bad about the broken screen, looks like a nice tv otherwise.
                    Eh, just a basic 42" LCD... if it were a KURO plasma I'd be weeping!
                    Still a shame, no doubt, hope that it was as-is, not like this after a repair...
                      • 12210
                      • U.S.
                      can't seem to get ahold of any plasmas, but I like the good clear picture on lgs and sonys.
                      • redriddick
                        • 93
                        • Ireland
                        No not after repair so no loss really to me!!!
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Makes me cringe thinking of my kuro getting cracked
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Trust me if you are a beginner at repairing tvs stay away from plasmas untill you gain more confidence, lots of things can go on them.
                              I think plasmas are easier than LCDs. You just need to know what to test. 9 times out of 10 I can fix a plasma by doing five simple voltage checks.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                I find the voltage testing and short testing easy just like lcd its just alot more work as the are lots of buffers and sustain boards to test. And if you have a bad y sus repair it and the x sus is also bad it will take out the new y sus just basially alot more work.
                                  Hm, if you say so. A little testing can eliminate that risk. Always use a light-bulb tester when testing plasmas on the Vsus rail.
                                  Bad master-slave inverter can also destroy opposite inverter (had that on a Sharp LC-52XL2E... what a nightmare.)
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • Ryan.man
                                    by Ryan.man
                                    02-04-2025, 12:23 PM
                                  • alltvrepairs
                                    Lg TCon test pins for screen test
                                    by alltvrepairs
                                    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                    Appreciate your help....
                                    06-13-2025, 06:33 AM
                                  • x_orange90_x
                                    TCL 50S535 bad tcon or panel issue?
                                    by x_orange90_x
                                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                    03-29-2025, 11:02 PM
                                  • smic717394
                                    by smic717394
                                    07-25-2024, 10:16 AM
