Vizio JV50P HDTV10A Sometimes sound, sometimes video...
  • kidyubyub
    • Feb 2015
    • 8
    Hi guys, I have just newly acquired one of these sets and the symptoms are as follows: from a cold start, you either get sound and no picture, or picture and no sound. If you turn off the set and let it be for about 15 minutes, you can turn it on again and you might just get both sound and picture at the same time. Picture looks fine and sound is great. Any ideas on where to start my troubleshooting? This will be my first crack at fixing a plasma, so any guidance would be greatly appreciated! I have searched the forum and have not found my exact issues, hence the new thread.
    Thanks in advance!
    Hey, you know computers... let me ask you something. I have this TV....
    • 12206
    • U.S.
    Re: Vizio JV50P HDTV10A Sometimes sound, sometimes video...
    read the stickies at the top of the list, pics are a good start.
    • CapLeaker
      Leaking Member
      • 8225
      try heating up the main board with a hairdryer, see what that does.
      • MagicSmoke
        • Feb 2011
        • 275
        First reseat all of the connections. Power and LVDS.
        If still not correct then we need Pics and some voltage measurements from PSU.
        If your PSU part # is AAX30284301 then read this thread for testing PSU.
        https://www.badcaps.net/forum/showpo...9&postcount=14
        If not then disregard.
        • kidyubyub
          • Feb 2015
          • 8
          Sweet! Thanks guys. Sorry about the no pics on initial post. I was not sure what or what not to do, so did not open unit up yet. Will do tomorrow and report back. Again, thank you so much for the guidance.
          • kidyubyub
            • Feb 2015
            • 8
            Finally got to open up the back of this heavy beast. Looks like a bad cap issue. Pictures show the evidence. I have heard of a cap kit for this set. Should I replace all the caps that come in this kit or just replace the bad ones? I would assume all of the caps from the kit. I hope replacing these parts will alleviate the issue!
            • freakaftr8
              • Oct 2012
              • 3743
              Replace all the caps in the kit for reliability reasons. the ones that aren't Looking bad will go eventually from heat and stress
              • MagicSmoke
                • Feb 2011
                • 275
                Replace all but the 4 large caps. I think there are 25 or so.
                The 2 large 450v 330uf,1 450v 68uf and 1 250v 820uf probably wont need changed.
                All of the caps have the same hours on them, some have more stress than others. I like to change all of them to prevent having to open it up and replace others at a later time.
                • kidyubyub
                  • Feb 2015
                  • 8
                  The places I see selling cap kits only show 16 at most. Is there a comprehensive list of all 25 and their values? I want to be sure to have all 25 at my disposal when I start to do the work. Thanks for you help!
                  • CapLeaker
                    Leaking Member
                    • 8225
                    you have the board. so identify the missing ones?
                    • kidyubyub
                      • Feb 2015
                      • 8
                      True, but I could make a mistake. Hence the request for a comprehensive list. This and the fact that there are no stores in my area that sell these components. If I missed something or made a mistake, I would have to order online again and delay repair. I would like to get it all completed in one shot if possible.
                      • MagicSmoke
                        • Feb 2011
                        • 275
                        Local stores are unlikely to have the correct capacitors. You will need to order them from Digikey or other electronics supplier.
                        Radio shack caps are not for use in a PSU.
                        Write down the values of each cap Uf and Volts then look for the series code. Usually 2 sometimes 3 letters on electrolytic caps. For instance RH, SK SG, and PT are what I have handy to reference.
                        Then search for manufacturers datasheet for each to find impedance and ripple current.
                        If they are somewhat common post the list and we can help determine what would be the correct replacements.
                        • CapLeaker
                          Leaking Member
                          • 8225
                          Just like Santa Clause: Making a list and checking it twice! If you missed something and have to reorder, that is "education money", so better to double check the double check!
                          • kidyubyub
                            • Feb 2015
                            • 8
                            Shut up... just shut up... you had me at Santa Claus.
                            • ChaosLegionnaire
                              by ChaosLegionnaire
                              09-13-2022, 09:02 AM
                            • ggil44
                              Vizio M65-E0 No Picture, No Sound
                              by ggil44
                              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                              09-03-2024, 08:30 PM
                            • LEECH666
                              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                              by LEECH666
                              Good day ladies and gentleman!
                              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                              01-19-2024, 05:46 PM
                            • shelby5041
                              vizio d40f-j09 no pic no sound standby always clear
                              by shelby5041
                              hi
                              anybody have experience with this model tv
                              07-19-2025, 06:58 AM
