Samsung UN32EH4003F Video Issue. Please help.
  • nstlfrk
    • Apr 2014
    • 166
    Not sure how to explain this so I uploaded pictures. Can anyone help? What could the issue be?
    • 12276
    • U.S.
    Re: Samsung UN32EH4003F Video Issue. Please help.
    need more info. on symptoms, can't tell from those pics.
    • CapLeaker
      Leaking Member
      • 8327
      seems like the left side on the second pic is darker than the right side?
        • 12276
        • U.S.
        hard to tell, I see the model number, but who knows what it is ummmm led, lcd, plasma???????????
        • sordids999
          • May 2013
          • 2161
          LED and looks like a panel fault maybe ?
          • nstlfrk
            • Apr 2014
            • 166
            Here is another picture with out the DVD player on. The issue is of course the center line or some what center. You can see it run up an down. The TV is an LED
            • nstlfrk
              • Apr 2014
              • 166
              UPDATE: The TV does not have that discolored line in it when I unplug the main board. It lights up good and even all the way across the screen. Should I assume that the Main board is bad instead of the panel itself?
                • 12276
                • U.S.
                not sure, heres a question, can you check these led panels by twisting the panel like the lcd panels?, if so could try that and see if anything changes on display, with all boards hooked up.
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                  09-07-2024, 05:50 AM
                • alltvrepairs
                  Samsung UE65RU7090UXZT main board issue no video out. BN94-14180M
                  by alltvrepairs
                  I have confirmed that I have a mainboard problem.
                  I have tracked no hardware issued on board so might be a software dump required.
                  I have searched a bit but wasn't able to find anything for my screen:
                  Here are some more details:
                  Panel: cy-nn065hgev1h
                  Main: BN94-14180M P08F
                  Your help much appreciated!
                  05-16-2025, 03:03 AM
                • Nairolf
                  Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                  by Nairolf
                  I have a Samsung DM32D display.
                  When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                  Here’s what I have tried so far:
                  1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                  2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                  3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                  From these tests, I suspect the problem might be on the mainboard. Could anyone...
                  08-24-2025, 03:47 AM
                • vincentedel
                  Samsung SyncMaster 740n Phase Control Issue
                  by vincentedel
                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                  04-22-2025, 12:33 AM
