Re: odd IC test reading, have 8 ics on bottom and 3 on top of board all give odd read
power supply voltages all correct with all boards hooked up, seems to be mainboard, trying to narrow down to component, but it no easy.
odd IC test reading, have 8 ics on bottom and 3 on top of board all give odd reading.
when the tv is on its just a snowy picture, can't see the menu, acted the same when it was screwed down, only had it on its edge to test ics on bottom.Leave a comment:
Yes but obviously this tv isn't working so first you need to know if the power supply voltages are all there at the connector.
Also when you are holding the board on edge it isn't grounded to the chassis like it has to be as you make no mention of using a clip to ground it.Leave a comment:
tested with tv on, all boards hooked up, tested ones on bottom of board, by holding mainboard on its edge, so it wasnt screwed down.Last edited by nomoresonys; 02-07-2015, 05:29 AM.Leave a comment:
The input voltage may not be there until the mainboard sends pson to power supply and the power supply in turn turns on the main board. Not enough information here to go by.Leave a comment:
on at least one of these ics on the bottom of board, the ground on one reads 2.5 on top and the same ground at bottom starts at 22mvs goes to 200 mvs flashes ol then starts back at 22mvs does the same thing over, strange two very different readings on the exact same ground?Last edited by nomoresonys; 02-06-2015, 01:37 PM.Leave a comment:
I think ic102 should have the same reading, ie, 2.5-G, 1.8-input, 3.3-output, but it reads 5.4mv-G, 13.3v-input, 7.9v-output. don't know, should the input ever be bigger than the output?, thanks.Leave a comment:
not exactly sure Alistair E, but I think they regulate voltage.Leave a comment:
acording to datasheet, ic101 should read 2.5v-ground, 1.8-input, 3.3-output, I'm getting 1.79-G, 4.7mv-Input, 3.34-output, looks like the input is way off?, and every dam one of these 11 ics has one reading in mv, strange.Last edited by nomoresonys; 02-06-2015, 01:19 PM.Leave a comment:
sorry guys, its my samsung lcd tv mainboard, I'll grab a pic. http://www.shopjimmy.com/samsung-bn9...main-board.htmLast edited by nomoresonys; 02-06-2015, 01:12 PM.Leave a comment:
A Vague Clue on what the device actually is would be good!
Is this a TV, a Video-Recorder or what? --What does this board do in that device and what are the IC's supposed to do??Leave a comment:
Are you talking about a Y-buffer board?Leave a comment:
odd IC test reading, have 8 ics on bottom and 3 on top of mainboard all give odd reading, get a volt reading on two of the pins but theres always a reading on one of the 3 pins that reads in mv, which is millivotes I guess, you think I need to maybe replace all of these, Thanks.Tags: None
Assuming...7 Photos -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
