Panasonic TC-P42S1 10 blinks, bad SC maybe solved.
  • lookimback
    • Aug 2013
    • 1489
    I've been working on this all day. Real pain in the @$$ because it seems to latch into protect mode and goes completely dead for about 5 minutes after you power it on. I did finally figure out that when the bad board was disconnected, you could hold the power switch for a minute and it will reset. If only I could get back those 3 or 4 wasted hours where i just unplugged it and waited...
    Anyway, the SM leads one to suspect the A board with a 10 blink code, but it is apparently not always the case. I determined that with the SC disconnected, I'd momentarily get 200+ volts on P2, and I didn't have that with it connected. That was enough for me. So, after a couple of frustrating hours with a cheap solder sucker and some desoldering braid (I really need a vacuum desoldering gun) I have a long list of shorted components. The SC is a TNPA4844AD.
    Q660 - RJK6026
    Q661 - RJP6065
    Q404 - 2PG011
    Q422 - 30G123
    Q423 - 30G123
    Q424 - 30G123
    D865 - 8688
    And I suppose it would be wise to replace the 2 driver ICs as well.
    IC501 - M8707FP
    IC521 - M8707FP
    I hope I didn't miss anything.
    ------------signature starts here------------
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P42S1 10 blinks, bad SC maybe solved.
    Q660 - RJK6026
    Q661 - RJP6065
    Q404 - 2PG011
    Q422 - 30G123
    Q423 - 30G123
    Q424 - 30G123
    D865 - 8688
    IC501 - M8707FP
    IC521 - M8707FP
    check the p5v and p15v resistance, could be other smd stuff gone like transistors and maybe inverter ic . not sure if anyone has repaired one of these, maybe the 5081 sc thread may give ideas to check anything related to q661
    • lookimback
      • Aug 2013
      • 1489
      Resistance to ground?
      • tw2005
        • Oct 2011
        • 6458
        yep
        D865 is RF101L4S
        This is a list from a 5 blink , bad SC tech bulletin in china
        Q16661、Q16422、Q16423、Q16424
        Q16404、Q16403、Q16402
        Q16701、Q16702、D16865
        IC16771、IC16464、IC16465、IC1677
        • lookimback
          • Aug 2013
          • 1489
          I'll get back on this later tonight, or over the weekend. Been a busy day. I appreciate the help though.
          • lookimback
            • Aug 2013
            • 1489
            I got around 4k ohms on SC20 between +15v and gnd. About 2m ohms between +5v and gnd. Of course, this is with the aforementioned components removed. I'll check all the smd transistors individually. Remaining diodes and FETs are ok.
            • tw2005
              • Oct 2011
              • 6458
              is the smd P fet ok?
              I really don't know this board but there are a few hits searching TNPA4844. One bloke got it going then it popped again , see no resolution at the end of that post. You may be lucky and just the fets but it may be a good idea to use that 5 blink list since it also has some of thos schmitt inverter ic and small smd transitors which drive q661 in there.
              these boards are I think are near impossible to find. i wonder what modus charges? But I guess you prefer the challenge
              • tw2005
                • Oct 2011
                • 6458
                I was just looking at this kit. 30 components!
                http://www.ebay.com.au/itm/TCP42S1-T...item2ed4221c77
                Q401 Q402 Q403 Q421 Q422 Q423 Q621 Q622 Q660 Q661 Q551
                D421 D422 D8XX D7XX? Q7XX AND Q7XX?
                IC521 IC7XX IC7XX? PLUS SURFACE MOUNT DIODE AND RESISTORS.
                Symtom; power LED blinks 7 & 10.
                • lookimback
                  • Aug 2013
                  • 1489
                  I can't seem to locate IC677. Everything else seems OK. Q403 and Q402 are more of the 2PG011s so I'll definitely add them to my list. What's the smd P fet? Also, how do you test the 5 pin things marked HA?
                  • tw2005
                    • Oct 2011
                    • 6458
                    this is probably not accurate but i found when they blew vcc - gnd would be shorted. Do you know what it is and have data sheet?
                    Also the 4844 is a cut down version of the 4782
                    https://www.badcaps.net/forum/showth...ghlight=2pg011
                    i know what I've done, I have IC1677 but will be IC1677xx, will have to check
                    P fet is right next to the end of one of the heatsinks SMD, will be Jxxx on it
                    • lookimback
                      • Aug 2013
                      • 1489
                      That is the most overpriced repair kit I've ever seen. I'd bet that most of those components are just fillers to justify the price.
                      • lookimback
                        • Aug 2013
                        • 1489
                        No, but I recall reading about it in your other thread.
                        • lookimback
                          • Aug 2013
                          • 1489
                          Ok, I found the P fet. It looks like a Vreg. It'snot shorted.
                          • tw2005
                            • Oct 2011
                            • 6458
                            Ic16773, This is one to watch with a blown Q661 if you go to schematic and look at the bigger picture
                            • tw2005
                              • Oct 2011
                              • 6458
                              cool, I've seen photos of them burnt out on 4782 sc boards
                              • tw2005
                                • Oct 2011
                                • 6458
                                probably a shotgun approach covering more than may be needed
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  All check over limit.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Yeah, ok but what is OL? I would have expected some resistance there that was measureable. on the 5081 boards I think around 6k
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      I checked them again and got 5k. That's weird. Maybe I just didn't press hard enough with the probes.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        sounds more like it. I think the protective coating on the board causes that. It's happened to me plenty. So 5k exactly or a bit more? Sounds like it's ok. All those feed off Ic771 so that would also mean the other would read the same. i would check vin -vout resistance to be confident ic771 is ok.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
