Pioneer plasma PDP-6020FD won't turn on
+ More Options
Posts
    Re: Pioneer plasma PDP-6020FD won't turn on
    Great. Bad panels are rare on these models and yours seems OK. I've seen only one on this forum with a bad panel, and that one lit up with lines on the screen. Get the Y-drive and resurrect this Kuro!
    • cm02WS6
      • Feb 2015
      • 12
      Glad to hear the panel isn't suspect! I will replace the Y drive and report back.
        Curious if you managed to fix this beast yet?
        • cm02WS6
          • Feb 2015
          • 12
          It took a little bit to get the new Y-drive but I finally installed it last night and it is fixed!!! Thanks so much for all your help! Between my own procrastination and messing with a bad service tech, the whole process has taken almost 9 months! However, it was the tech mentioning this forum that brought me here, even though I couldn't find anything related to a Pioneer plasma that he said he was checking on in that time frame. Glad to finally get this behind me.
            Great to hear it's fixed!
            • cm02WS6
              • Feb 2015
              • 12
              Thanks! Although frustrating at times, I did learn a lot and I am happy I was able to fix it myself, which wouldn't have been possible without your help.
              Unfortunately, now I need to start figuring out how to sell this beast. I got this from my mom after my dad passed away because she thought it was too big for her living room. Even though I know it is a very nice display, not using it for the past 9 months showed me I don't value having a TV this big or this nice, so I figure I should try to sell it and use the money elsewhere. Any tips on resources to sell high end A/V equipment like this?
                Old Kuros are difficult to sell. These are great TVs but since they lack the smart features of the newer panels you'll be selling to an enthusiast directly. Try places like AVSForum. Craigslist is probably going to be difficult. eBay may work. They're worth anywhere from $500 to $1,000 if you can find the right buyer.
                I highly recommend you connect it all up and watch a good dark movie on it,m at least before you sell it... you might just change your mind. KURO is all about the image contrast, and once set up correctly it blows away even modern display panels.
                • Shinju
                  • Mar 2014
                  • 1239
                  Craigslist or if you are on Facebook utilize your local buy/sell groups and or use an app called offer up its like a local CL classifieds on your phone I use it all the time.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Dont sell it !
                    Honestly its worth its weight in gold they are beautiful tvs when it comes to picture and very reliable !
                    • ccudrew
                      Jeeper
                      • Jul 2015
                      Where did you get the Y drive?
                      • bweier23
                        • Jul 2015
                        Where do you check the vadr voltage?
                          At the connector marked Vadr on Y drive or power board
                          • mike keane
                            • Sep 2017
                            Mine is doing the same thing, 211 volts on VSUS when the Y drive is unplugged, about -.3 volts when it's plugged in. I have 75 volts on VADR either way. I'm going to order a Y drive board!
                            • mike keane
                              • Sep 2017
                              Replacing the Y-Drive board repaired mine as well. Thanks Guys!
                              • pixelcap
                                Pioneer Plasma 111FD To Solder or Not to Solder.
                                by pixelcap
                                Hello out there in Badcap land.
                                I have a Pioneer plasma that gave me the dreaded 8 red blink and shutdown, I have been trying to trace the failure points. On my last inspection while replacing a Y Sustain Board I noticed on the original and replacement board some missing solder, the points of connection
                                are from the Digital Address Board and the Buffer Boards. I have included the pictures, should I resolder these points or are they unsoldered intentionally? Any help would be much appreciated.
                                Thank you
                                Pixelcap...
                                03-08-2025, 07:10 PM
                              • Phil Stasik
                                Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
                                by Phil Stasik
                                Pioneer Pro-FHD1 Elite. Failure to power on.
                                I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
                                We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
                                01-19-2023, 01:22 AM
                              • Bushcat
                                Pioneer PL-X9 motor speed control wobble
                                by Bushcat
                                I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
                                Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
                                BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
                                05-24-2023, 03:36 AM
                              • EduCabral
                                [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
                                by EduCabral
                                I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
                                While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
                                🔧 Details:
                                • Model: YT-M06
                                • Interface: Pioneer 1
                                • MCU: Fujitsu MB89F202
                                • Goal: Find a valid .bin firmware file or memory dump from a working unit
                                I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
                                07-15-2025, 12:26 AM
                              • Wiggly_worm
                                Pioneer plasma panel fault codes
                                by Wiggly_worm
                                Has anyone had any experience with with pioneer plasma panels, this one is in an NEC PX-42XR4G and it powers up for around ten seconds then goes into standby with a red led on digital board flashing six times and refuses to power up !...
                                02-24-2020, 09:55 AM
