working on a insignia M#ns-37d20sna14.no led backlights,audio ok.0v between led+ & led- pins.what should the led voltage be?getting a backlight on command from main.new to led sets.suspect power supply.
led voltage?
Re: led voltage?
It can be from 40V to over 100V depends on the LED string setup.
Any good clear pictures of the boards?
Did you monitor the Voltage during the start up to see if there is Voltage presents for seconds before it shuts down?Never stop learning
i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
VCCIO voltage ok
VCCSA Voltage OK
VCCPLL Voltage OK
Ram Voltage ok
RamVTT OK
VPP 2.5 OK
But No Core Voltage
and i want to this vrm ic datasheet or pinout (ISL69269)
anyone have this ic pinout voltages?...06-25-2025, 07:19 AM -
by electron_jjHi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
I have been inspecting and testing the capacitors and diodes in the power supply board to try to... -
by sam_sam_samI found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
Now... -
3+1 Voltage Regulator for IMVP-7/VR12 CPUs
Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
Based on Intersil's Robust Ripple Regulator...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:24 PM -
by sam_sam_samI want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
https://www.ebay.com/itm/116497313155?var=416785404161
Here are some of the description from the eBay seller
The main parameters:
1. Product name: High-power non-isolated DC boost module power supply.
2. Product model: 100A2000W.
3. Input voltage: DC12V-60V.
4. Input current: 100A (maximum).... - Loading...
