UE40D5000 red led blinking (PSU, Main board and T-con changed)
+ More Options
Posts
  • wilecoyote
    • Jan 2015
    • 6
    • FRANCE
    I have an UE40D5000 that does not start and the red light is blinking... I can also heard a sound that seem to come from T-con board or panel :s...
    I changed the PSU, the main board and the T-con board, so I'm without new ideas!
    If somebody has any idea on what I can do to solve this problem ??
    Re: UE40D5000 red led blinking (PSU, Main board and T-con changed)
    Does the light blink continuously?
    If you disconnect the T-con LVDS cable, does the light blink then go out?
    • wilecoyote
      • Jan 2015
      • 6
      • FRANCE
      Yes it's blinking continuously...
      Led stays on for 2 or 3 seconds then blinks several times...
      It's the same if I disconnect the TCON LVDS cable.
        Ok, disconnect the cable between the main board and power board. Does the backlight come on?
        • wilecoyote
          • Jan 2015
          • 6
          • FRANCE
          No, the backlight stays off... Should I search for a backlight problem ??
            To me that indicates backlight fault (power board or LEDs inside panel)
            • wilecoyote
              • Jan 2015
              • 6
              • FRANCE
              Ok. I already changed the power board... Do you know if it's easy to test/change the LEDs inside panel ??
              • mmartell
                • Oct 2013
                • 3189
                Not easy but doable if you're careful. I have a thread here on a un55d6000 in which I did just that. Good luck.
                  Seems D-series is bad for panels and bad for LED failures, both difficult to fix (panels impossible in most cases.) Ah, Samsung...
                  • wilecoyote
                    • Jan 2015
                    • 6
                    • FRANCE
                    Ok... Thank you guys!!! So, nothing to do anymore with that... I will try to fix the LEDs anyway... I think I have to carefully open the panel :s
                    mmartell can send me a link to the post you're talking about ??
                      Here, I believe...
                      https://www.badcaps.net/forum/showthread.php?t=34566
                      • labo555
                        • May 2015
                        • 14
                        • Italia
                        prejudice to unite myself to the problem I also have a similar problem ...not only lights the red LED flashes
                        just that to me pulling the cable the main board and power board. the backlight is on ... come on a regular basis
                        you have tips? thank you in advance
                        sorry for my bad english
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Images of the boards ? I had the C series blinking Led and restarting failed Bga solder on the mainboard Cpu.
                          • labo555
                            • May 2015
                            • 14
                            • Italia
                            thanks for your answer
                            • labo555
                              • May 2015
                              • 14
                              • Italia
                              help me...
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Ok firstly have you started checking the main voltages from the Psu ?
                                • labo555
                                  • May 2015
                                  • 14
                                  • Italia
                                  ok I start to work and let you know as soon as possible
                                  thanks
                                  • labo555
                                    • May 2015
                                    • 14
                                    • Italia
                                    these are the measured values
                                    2.1.pwn_dm ------ 12.46 / 13v
                                    4.3.n.c -------------12.46 / 13v
                                    6.5.blu_on/off --------- 13v
                                    8.7.gnd -----------------
                                    10.9. gnd ----------------
                                    12.11. a5v ------------- 5.36v
                                    14.13.5. power on/off ---------------- 5.36v
                                    • labo555
                                      • May 2015
                                      • 14
                                      • Italia
                                      I have to check more
                                      • labo555
                                        • May 2015
                                        • 14
                                        • Italia
                                        ADD THAT LED just connect the power supply flashes six times
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • TerraPhantm
                                          Sony A8H to A80J mainboard upgrade possible?
                                          by TerraPhantm
                                          I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                                          So I decided I'd experiment a little bit.
                                          I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                                          When...
                                          08-15-2023, 08:10 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • maxim2511
                                          LG 55EC930V OLED - swich on swich of no screen
                                          by maxim2511
                                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                          Then I get an idea to take it apart and clean boards from dust.
                                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                          05-14-2021, 02:21 AM
