Philips 42PFL9603D No ambilight + diff mobo?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hey guys ,
    Got a 42PFL9603D that had been sitting here doing nothing for almost 8 months now because of a bad main board. I was not able to find a new main board because they are simply not available.
    Last week i found a main board from a 42PFL7403D. It has the same part numbers and all connections are the same EXCEPT 1 connection. ( 1M59 ).
    On the original board i have that connector but on the replacement board the connector is gone. ( never was there ).
    My problem is that the ambilight is not working. I tried different remote's and i can't find the option in the menu??
    As the tv was disassembled for 8 months i now just don't know how to connect the ambilight to the PS. There are not much connectors left on the power supply and i know 1 connector is black , so 1 connector remains left.
    My main concern is , do i need the 1M59 to get the ambilight to work on this tv?
    In the service manual i find this :
    1M59
    1. SCL-AMBI-3V3 2. GND
    3. SDA-AMBI-3V3 4. GND
    5. GND
    6. +3V3
    7. GND
    Can it be that 42PFL7403D uses a different ambilight connection and that thats the reason the connector is not there?
    thx!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Philips 42PFL9603D No ambilight + diff mobo?
    Here are some pictures and SM does not say how to connect the ambilight. ( dont wanna just try )
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      Ok i soldered the connector to the main board and connected it to the PS , still no ambilight.
      Ambilight could be bad of course…. anyway to test this?
        It can be turned on or off by the user if they do want the ambilight function?
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          You mean in the menu? Or remote control? Via rm it does not turn on
            You need to enter the correct option codes for this set. There is usually info in the service manual. Option code list will be printed on chassis on a sticker somewhere. Some sequence of 5-20 numbers, 2-3 digits each. You enter them in sequence in some mode and it configures the board for that build variant.
              http://www.p4c.philips.com/cgi-bin/c...scy=HK&slg=ENG
              How do I adjust Ambilight?
              How to turn feature on/off:
              Press the 'AMBILIGHT ON/OFF' button on the remote control or:
              Press the 'MENU' button on the remote control.
              Press the cursor right button to AMBILIGHT.
              Press the cursor down button to AMBILIGHT.
              Press the cursor right button to set ON.
              Press the 'MENU' button to exit the menu.
              How to adjust if wrong color of light:
              Press the 'AMBILIGHT MODE' button on the remote control or:
              Press the cursor down button to AMBILIGHT MODE.
              Press the cursor right button to the desired mode.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Budm , there is no ambilight option in the menu thats the problem!
                I will check what Tom said.
                thx!
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Tom , why do i need to enter these option codes? They are both ambilight? Just confused.
                    They change everything from the model number in system menu, to TV region, screen type and enable ambilight. You have to enter all of them. It's possible to change them as well from a TV with no picture, but I can't remember exactly how (it's how you can install 720p Philips main board in 1080p TV, even if screen is messed up)
                    Example:
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      In the picture you provided with the codes and in the service manual they mention "Active SAM". Do they mean the service menu?
                        yes
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Oke , thx! Its normal for a service guy to know that haha!
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            Hey Tom ,
                            Im in the service menu but i don't see how i can change the options1/2 ?
                            I used service "123654" and its set to 7403D , i got the option codes for 9603D but i don't know how to change them? Manual says "options" but i don't have it.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Ah thats not the SM! :o
                              Found it!
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                Installed the options for this TV ( 9603D ) in the right menu and stored it. Also turned the tv off/on and still no ambilight.
                                Ambilight dead? Anyway to test this? External power supply?
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  It still says 7403D , options menu ok ,i can select ambilight but it does not turn on!
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    I checked the service manual and on 1T59 it says i must have +3v3 but i have 0v.
                                    I do have the 25V on 1T90.
                                    Is this a software problem or a hardware problem?
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      I removed the ambilight from the back cover and there are 2 boards. On the "main" ambilight board which holds all the connectors i noticed that there was 1 connector not used. It has the same connection as the connector thats used for the 2nd ambilight board.
                                      I removed the cable from ambilight board 2 and placed it in the other connector on the ambilight "main" board and the 2nd ambilight board turns on. ( It does not change colour or react to the ambilight on/off button ). Thats probably because its bypassing something?
                                      So that board is working but i still don't know if the other board works or not! Also , why don't i have 3.3v on the PS?
                                      Could this be a software/firmware problem? At first i didn't have the ambilight function in the menu , after changing the option codes i now have the ambilight option BUT when i use service code "123654" the main board is still on "7403D".
                                      Do i need a firmware upgrade to 9603D?
                                      Hope that someone can help me with this last issue!
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        The 7403D does not have the ambilight , can it be that the mainboard has different hardware even though the numbers are the same?
                                        • dominik0801
                                          Philips 55PFL6008K/12K Ambilight not working
                                          by dominik0801
                                          Hey,
                                          I just got the TV mentioned in the title the other day.
                                          Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
                                          It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
                                          Everything is perfectly fine with it, but the Ambilight just won't do anything.
                                          At all.
                                          Won't work on Dynamic, won't work on Static. Not a single...
                                          11-28-2022, 01:24 PM
                                        • kew1701
                                          Philips taw6205 ambilight speaker STM32 mcu dead
                                          by kew1701
                                          Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                                          04-09-2025, 03:59 AM
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          Yesterday, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
