Burnt chip on Samsung X-buffer
  • runeazn
    • Jan 2015
    • 19
    • Netherlands
    Anyone an idea which high low rectifier it is?
    At least I think it is one.
  • drussell
    • Nov 2014
    • 144
    Re: Burnt chip on Samsung X-buffer
    That looks more like some sort of controller IC and there are probably shorted transistors downstream of it. Trace out where it goes and check all the large IGBT transistors for shorts and everything in between if there are small surface mount ones connected off that chip they are probably blown also.
    • Ltank
      • Jun 2013
      • 776
      Give us Make and Model and IC part#. This way maybe it can be located by schematic or techs that have access to a board.
      • popeye
        • May 2011
        • 155
        You will most likly have to replace both buffers
        • runeazn
          • Jan 2015
          • 19
          • Netherlands
          That sucks, tv still turns on btw. Havent taken a look but I think its still showing normal picture.
          Also I'll post all information ill be able to find soon.
            Hmm, that looks like Ve-bias circuit so it would cause dim/underdischarged image or sometimes pink tint.
            • runeazn
              • Jan 2015
              • 19
              • Netherlands
              you are compeltely right, when it was burning it had purpleish glow with a dim image! I left the xbuffer connector on the pdp display? This somehow got the IC burning.
              The make of this tv is philips.
              model : 42PF7320/10
              PDP s42SD-yd07
              and the model xbuffer is shown in the picture.
              • tw2005
                • Oct 2011
                • 6458
                It's a FET driver, I had a couple of guesses at it already. possibly one of them will work maybe you guys can work out from the cct which type of driver. both rated at 600v
                https://www.badcaps.net/forum/showthread.php?t=43613
                • runeazn
                  • Jan 2015
                  • 19
                  • Netherlands
                  Isn't the same chip findable on the ybuffer or something? As that is still working.
                    This is part of Ve(bias) so probably not...
                    • runeazn
                      • Jan 2015
                      • 19
                      • Netherlands
                      I guess, I'm going to need to buy a used xbuffer? As no1 can indetify the FET driver?
                      • tw2005
                        • Oct 2011
                        • 6458
                        found this, looks like different part number but board looks same and off the same panel,
                        http://www.shopjimmy.com/samsung-lj9...main-board.htm
                        • runeazn
                          • Jan 2015
                          • 19
                          • Netherlands
                          Yeah looks similar problem is. I can't identify the chip on their picture
                            $21 isn't bad, you can't get board cheaper in Europe somewhere?
                            • runeazn
                              • Jan 2015
                              • 19
                              • Netherlands
                              They go for 80$ here.
                              I tried to buy my x-main on Alibaba.com not sure if it will arrive, but I paid with creditcard so it should be fine.
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • DynaxSC
                                ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                by DynaxSC
                                Hi
                                I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                08-04-2025, 12:20 PM
                                09-07-2024, 05:50 AM
                              • hoak
                                Help me identify this burnt chip
                                by hoak
                                I have a Asus Q540v laptop which has no power. I opened the laptop and found this burnt chip. Unfortunately, the marking on the chip is damaged. Anyone able to identify this chip?
                                THanks,
                                07-05-2025, 07:58 PM
                              • miccodan
                                Advice / Help with Dell Inspiron P59G001 with burnt chip (PU5101)
                                by miccodan
                                Hello All,
                                This is my first post here, I have worked in IT all my life however my knowledge when it comes to component level motherboard repair is extremely limited. That being said I have been attempting to learn more in this area. This laptop in question had liquid spilled on it a couple years back. No repair attempt was made at that time.
                                Upon plugging the laptop in and attempting to power it does not do anything besides show a white status light on the front that blinks on and off continuously. I then proceeded to remove the board from the laptop and inspected further....
                                12-05-2023, 09:09 PM
