Samsung LA40B650T1FXXY BN44-00264A PSU FS801S fuse blowing
  • Langfo
    • 3
    Hi There
    I have a short circuit in my BN44-00264A PSU. The FS801S blows immediately when powered up. There are no smells or visibly obvious suspect components. I've been reading through related forum posts and I think I have narrowed down the problem.
    I removed components QI820 and QI821 based on a forum thread I was following (but I think this may have been unnecessary in my case). I tried the lamp across the fuse terminals. In my case I have electrician test lamps and these glowed brightly.
    A few days later I discovered ~zero resistance across the +/- terminals of BD801S while it was still in circuit. I removed BD801S and still measured the same resistance across BD801S.
    Yesterday, I noticed ~zero resistance across the Gate and Drain and the Drain and Source of QP801S. I removed this component and I'm now measuring an open circuit. Does QP801S sound like the faulty component.
    Should I replace all the components I have removed or just the QP801S.
    Also, I'm in Australia. What is a good place to source components? I have found rs.online.com which have the QI820 & QI821 components. They have a STF11NM60ND. What does the D on the end mean? Is this the same component as STF11NM60N.
    http://au.rs-online.com/web/p/mosfet...stors/7612745/
    They don't have the Bridge Rectifier TS6B05G, they have a KBU605G
    http://au.rs-online.com/web/p/bridge...fiers/6875894/
    Has anyone tried alibaba.com or aliexpress.com for components?
    Mark
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Samsung LA40B650T1FXXY BN44-00264A PSU FS801S fuse blowing
    Comparing the datasheets looks like KBU605G will work in place of TS6B05G.
    If your fairly sure you did not overheat the components removed, and they test good you can reuse them.
    Extra letters on P/N's are usually for inventory control or designate if on tape or loose.
    I have had some luck sourcing IC's on ebay.
      "A few days later I discovered ~zero resistance across the +/- terminals of BD801S while it was still in circuit. I removed BD801S and still measured the same resistance across BD801S" Where is this BD801S? I cannot find in in the diagram.
      "Yesterday, I noticed ~zero resistance across the Gate and Drain and the Drain and Source of QP801S. I removed this component and I'm now measuring an open circuit. Does QP801S sound like the faulty component." That means the PFC IC UP801S and the resistor/diode network connected to the Gate of the MOSFET may be damaged also. I would not replaced the PFC MOSFET QP801S, 802S without replacing the IC at the same time or you will take a big chance blowing the new MOSFETs.
      BTW, TOM66 website has the diagram for your board
      • selldoor
        Slow Learner
        • 7870
        In this SJ picture it is top right corner near the 2 red/orange film caps
        http://www.shopjimmy.com/media/catal...264a-top_7.jpg
        The OP really needs to post pictures of his own boards
        • tw2005
          • Oct 2011
          • 6458
          Originally posted by Langfo
          Hi There
          Mark
          Something i notice is the TS6B05G is TS4B package 3.7mm thick, larger pin spacing.
          KBU605G is KBU 7.1 mm thick, pin spacings are 2mm narrower between the legs
          you can get a visual idea here
          looks like an oddball , found RS1005M which also seems hard to find locally.
          UTSOURCE takes 3 weeks though from china, some on ebay but expensive way to go. The prices are USD so with the $ sinking keep that in mind.
          Also watch out for those on backorder parts at RS, sometimes they are automated and keep refreshing. They had some parts i was after and they were endlessly on backorder and never came in even after 12 months, suspect they became obsolete or discontinued
            Here is the diagram.
              Thanks, I see it now.
              • Langfo
                • 3
                Hi There
                Thanks for all the replies and sorry for not posting photos of my board or the schematic diagram.
                I've taken on board everyone's advice and comments. I've place an order with Utsource.net for the MOSFETs, Rectifier and the PFC chip as well as the diodes feeding into QP801S, QP802S.
                I'll update when I receive the parts and solder them in.
                • politics
                  • Jan 2015
                  • United Kingdom
                  LG TV 42px5d-eb power not switching on
                  • nestor_nelida
                    • Sep 2017
                    • 5
                    • España
                    What happened finally? I have the same problem.
                    • motophil
                      • Mar 2021
                      • 3
                      Too bad @Langfo never posted the solution
                      I have pretty much the same problem, FS801S blown and zero resistance across +- (or -+) on BD801S while still in circuit, which for my take only leaves four components that might be short - the rectifier BD801S itself, one of the capacitors CP801S and CP802S or the transformer/transducer LP801S (least likely for my take).
                      On my board the QP801S and QP802S have ~300Ohms measured with a digital multimeter on GS or GD (or SG or DG for that matter), and 0 Ohms for DS or SD - to me that sounds fine, right?
                      So my next step will be to take the board into work on Monday, more professional tools there, and take out BD801S, and the capacitors CP801S and CP802S to measure them out of circuit. I hope that just one of them blew and nothing else...
                      - Philip
                      • R_J
                        • 9580
                        If you can unsolder pin 6 of LP801s then you can isolate the bridge rectifier from the mosfet circuit.
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          I would suspect either one or both mosfets are shorted so I would take them out to check.
                          • motophil
                            • Mar 2021
                            • 3
                            And you were spot on. The rectifier is fine, the short across +- came from the mosfets across various components on the board. One of the mosfets is shot, 0 Ohm on DS.
                            It was all a bit a b*tch to desolder because there are rivets in some of the PCB holes.
                            So I have to replace the mosfets and will also replace the UP801S (FAN7530), since that quite often seems to be the cause for the mosfets to blow.
                            Now, what's a good source of components in europe? Mouser and Digikey both have the components but charge €20 for shipping to Germany. Nikko Electronics sells from the UK on ebay... anybody know if that's a trustworthy source?
                            - Philip
                            • petehall347
                              • Jan 2015
                              • 4433
                              • United Kingdom
                              - Philip
                              RS components
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                I would imagine there are plenty of ebay suppliers since most commercial companies do have a minimum purchase cost before postage is free.
                                You could look at cpc.co.uk or Farnell and see if they have what you want and their delivery charges.
                                • ivtec
                                  • Dec 2008
                                  • 1967
                                  https://www.shopjimmy.com/samsung-bn...t-repair-kit/\
                                  • motophil
                                    • Mar 2021
                                    • 3
                                    OK, so I got the FAN7530 and the STF11NM60N off ebay from nikkoelec, an UK-based vendor to avoid the shipping times from China on the one hand and the shipping cost of vendors like mouser or digikey on the other hand.
                                    They shipped TO-220 housing (with metal tab) instead of TO-220FP (isolated)
                                    A good thing I could get hold of two heat condcutive TO-220 pads and fitting plastic screws to mount them. Now the TV's been running for 90mins without problems, smells or smoke.
                                    Thanks everybody for the help,
                                    - Philip
                                    • onkeltom6
                                      • May 2022
                                      • Deutschland
                                      Hallo Philip,
                                      Wars das mit der Reparatur und läuft der TV noch immer ?
                                      Stehe derzeit vor dem gleichen Problem. 6.3AT Sicherung ist durch und an den Mosfets und dem Gleichrichter messe ich einen Schluss...
                                      Gruß
                                      Thomas
                                        How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                        by sam_sam_sam
                                        About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                        Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                        12-14-2023, 07:45 PM
                                      • grimacelord
                                        Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                        by grimacelord
                                        Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                        After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                        I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                        10-24-2024, 12:31 PM
                                      • 90Ninety
                                        Dell XPS 8100 Motherboard VRMS keep blowing
                                        by 90Ninety
                                        I wanted to save this thing from E-waste ... I helped a neighbour with their Dell PC , it had a blown visably blown VRM causing a short on the 12V EPS ..
                                        I replaced this VRM which fixed the short but, the high side VRM's keep blowing , seemingly the same two phases .. I replaced the low side mosfets on the respective blown phases . Though still the High side VRMS are blowing ..
                                        After a few minutes one of the four phases will get extremely hot , then blow ..
                                        I purchased replacement VRMS both High Side (72T02GH) and Low side (86T02GH). Pictured below , I just...
                                        10-05-2024, 08:36 AM
                                      • Sik_6ty_Sixx
                                        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                        by Sik_6ty_Sixx
                                        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                        02-18-2025, 05:06 AM
                                        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                        by sam_sam_sam
                                        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                        This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                        12-29-2024, 07:18 AM
