Toshiba 32w1333d - Flashing red/green standby light
  • Fatness
    • Jan 2015
    • 8
    I have a Toshiba 32w1333d that does not turn on . The standby light flashes red and green. I have tried turning the set on with the remote but that makes no differance.
    The psu board is Vestal 17IPS11 300413-R4 , The psu seems to be ok, the caps looked ok but I changed them anyway and that didnt make any differance. I also tried disconnecting the T-Con board but the light still flashes.
    I now can only assume the fault to be on the main board which is a vestel 17MB95S-1 v.1 211212 23114325. I have looked on all the groups but with the tv only being 18 months old there is no guides for this fault even though a few people have asked about the fault. I have looked everywhere for a replacement mainboard, I can find 17MB95S-1 v.1 211212 boards buy not with the same 23114325 and this last lot of numbers seem to change with different model numbers.
    I would like to fix this set and not have it as a paper weight - Help !!!
  • Kilroys
    • Feb 2014
    • 70
    • Sweden
    Re: Toshiba 32w1333d - Flashing red/green standby light
    Software error.
    Unfortunately, the software is tied to the type of panel you have.
    Which panel do you have?
    • Fatness
      • Jan 2015
      • 8
      The main av board is as listed above.
      The screen panel model is VES315WNDL-01
      It also says LC320DXJ-SFE1
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        There are many versions of these boards that are made for specific versions of tvs, replacing them is a nightmare you need to get the model numbers so you need to try to repair the old main board. Do you know where the epprom is ?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Also have you definatly confirmed that the psu is fully working ?
            Software is available on the Toshiba website, for the main flash. No software for mboot, but I suspect that's the same for all 17MB95 boards.
            More Vestel trash failing I see (no Toshiba in these sets ... you think you're buying a reliable set but it's just re-badged supermarket rubbish.)
            • Fatness
              • Jan 2015
              • 8
              ReeceyBurger123 - Yes I believe I have found the eeprom -u10
              I dont have a toshiba account but I have a friend with a tv shop and I guess I could ask him to order a new eeprom for me as long as it comes programmed.
              Is there any way to reset them like you can do on a samsung?
                Publicly available from Toshiba, I mean....
                http://www.dl.toshiba.com/DLY/index....ion=GB&lang=EN
                • Fatness
                  • Jan 2015
                  • 8
                  Thanks tom66 but that download is for putting on a usb pen drive and you need to be able to access the on screen menu to use it but the tv does not turn on
                    If you have mboot.bin for your set (should be common for all 17MB95) and edit the .txt file to remove "#" from beginning of "mboot" lines then it should work. You hold "OK" while powering the TV on and it will update without menus.
                    • Fatness
                      • Jan 2015
                      • 8
                      I have downloaded the file "upgrad_mb90.bin" and I have opened it in an editor but there is no # at the start.
                      Maybe I am just thick and doing it wrong lol
                        There should be a txt file like usb_auto_update.txt...
                        • Fatness
                          • Jan 2015
                          • 8
                          No tom, I went on that link you sent me and the exe file just unstalled a bin file
                            Hm, maybe it's not possible on 17MB95, sorry. It is possible on the MB62s...
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              I honestly hate it when these junk boards fail because replacing them is a complete nightmare.
                              • Fatness
                                • Jan 2015
                                • 8
                                CHS sell the new board but it is £160 lol
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  I would be inclined to still try this- it may still read from the USB.
                                  I have read the instructions and you dont need to be able to see anything on the screen - you just press buttons on the remote.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Not worth it for a vestel lol
                                      Not really worth it for any TV... who would spend £160 fixing a 32" basic smart LED-backlit TV? I often wonder whether CHS sells any of those boards... surely, they must, but who on earth to?
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Are you sure you can not repair it at all ?
                                        If not keep the tv around for a few months and see if a board comes up for cheap.
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • 7ony
                                          Samsung plasma - flashing standby light
                                          by 7ony
                                          The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                          Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                          Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                          No visible...
                                          08-31-2020, 05:18 PM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • naddaw000
                                          Toshiba 55U7863DG - green light blinking (17MB130S)
                                          by naddaw000
                                          Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                          I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                          12-02-2023, 01:35 PM
