Toshiba 32w1333d - Flashing red/green standby light
  • zomi
    • Nov 2011
    • 505
    #41
    Re: Toshiba 32w1333d - Flashing red/green standby light
    upside down means incorrect firmware
    needs to be reflashed with correct type
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #42
      +1 Also did you do the core update if so that wont work which is why its messed up ?
      • michael dranfield
        • Jan 2016
        • 232
        • England
        #43
        in this model failure of the led strips is very common, if you have a bench power supply apply 76 volts dc to the panel and it should light up, , a simple test for the psu board is to make a small box with 22 while leds in series and two croc clips , this will give you instant diagnosis with no time spent, however I must warn you I have had these strips go intermitent, one set I had ran for 3 days solid and then the back light went off one led o/c , charles hyde can now get the led stips to order from vestel ,
        In the 40 inch Toshiba sets with a samsung screen and the pulse width modulator built into the screen itself the most common fault of no or intermitent backlights is nothing more than a dry joint on the backlight plug/sockets, the strips are joined in the center by white plug/sockets, you will see the connectors have gone brown and do not measure zero ohms.
        As for the upside down pic , some vestel screens are mounted upside down with the LVDS board at the bottom of the screen, this indicates you have loaded the wrong firmware.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #44
          Sordids gave me his board, and it was not the firmware ! I loaded the proper firmware for that panel and it was still messed up and upside down with lines, swapping the board fixed it slightly odd however dont think it was the firmware.
          • michael dranfield
            • Jan 2016
            • 232
            • England
            #45
            A copy of the firmware would be nice !
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              Clam down yeah ! Jezz what not ask nicely ?
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #47
                I have it on a Up02 Usb will make a raw file and attach tomoz or whenever im free. Cost me £24 for it but I will put it up for FREE, bloody hell lol.
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  #48
                  You never know what I may be able to help you with ! I love vestel sets , always have done since the CRT days.
                  What would be nice if some one here is into code dissasembly and writing could write a program where you insert a USB stick into a working set and it downloads the program onto the stick , I know this can be done because on some models you can do this but only to store customer settings /tuning ETC for hotel use.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #49
                    Ahh right fair play, Vestel made CRT's ? I will make a new thread when I compress the firmware and upload it then.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #50
                      Ive serviced well over 150 Vestel Lcd and a few Plasma sets by now, so many faults.
                      • michael dranfield
                        • Jan 2016
                        • 232
                        • England
                        #51
                        I have loads of vestel schematics, big makers like sony, samsung , LG dont even publish service manuals with diagrams in any more, I dont know many people who like vestel sets but its one of the only sets you can fault find to component level , sadley many sets are coming in for repair now fitted with UMC chassis fitted , even sharp have droped vestel and are using UMC chassis.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #52
                          Its all slowly going to trash, Umc are not too bad better than Vestel IMO but overall both are trash. Also reading Vestels schematic is a nightmare they are just messy and all over the place.
                          • matyka
                            • Jan 2015
                            • 179
                            • Uk
                            #53
                            Hello,did you managed to upload this firmware ?
                            I could send you a nice cold beer for it )
                            I have the same Toshiba flashing red/green standby light.
                            Thank you in advance .
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #54
                              http://www.dl.toshiba.com/dtv/NA/GB/EN/32W1333DG.html
                              • MOSSEP
                                Monitor Audio RSW12 - Green light, but no sound
                                by MOSSEP
                                Hi
                                Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                I have already tried replacing all of the...
                                01-26-2025, 08:33 AM
                              • MOSSEP
                                Monitor Audio RSW12 - Green light but no audio
                                by MOSSEP
                                Hi
                                01-26-2025, 08:18 AM
                              • 7ony
                                Samsung plasma - flashing standby light
                                by 7ony
                                The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                No visible...
                                08-31-2020, 05:18 PM
                              • lcdcaps1
                                820-2610-A Sys onewire help, no green light. Please help from the gurus
                                by lcdcaps1
                                Hi
                                I have an 820-2610-A motherboard that has no green light.
                                I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                The sys onewire circuit on this model and others is more involved
                                I was hoping if anyone knows about this and how it works, can reply and let me know
                                I know this is an old model but I am sure there are people who still works on these or knows about them
                                I get 1.1v on the C7771 capacitor and will replace...
                                11-06-2023, 01:28 PM
                              • naddaw000
                                Toshiba 55U7863DG - green light blinking (17MB130S)
                                by naddaw000
                                Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                12-02-2023, 01:35 PM
