2011 Samsung 51" Plasma clicking no power on - some progress made
  • scotty562
    • Jan 2015
    • 5
    Hi guys. I've come into possession of a pn51d530a3fxza. Hopefully I'm using the correct terminology. I did try searching and I found a lot of posts with similar issues, but very very few ever come to a resolution which is why I'm posting.
    Symptoms:
    The tv does not power on. It tries about 6 times and the relay on the main power board clicks as it tries.
    Troubleshooting:
    I visually inspected the boards and couldn't find anything obvious like puffed caps.
    The second thing I tried doing was unplugging the y-main. When I did this the tv did its power on jingle . Next I plugged the y-main back in and tried unplugging the x-main and I then got the same jingle. So from my research it's looking like I need a x-main board. On this tv the power goes into the y-main and then from the y-main into the x-main.
    Also from my research it looks like defective firmware caused a lot of problems in these models with the x and y mains, but I looked on Samsung's website and the firmware that's available for my tv is older than the tv is which is troubling. I guess it's possible they put old firmware on the tv during manufacturing. This info may not apply to my exact model though I'm not sure.
    Next I looked at x-main boards on ebay. I put the model number that is listed on my x-main and the results are x-mains that look similar, but are slightly different. I'm assuming this is just a different revision? All of the connectors were in the correct places.
    So basically what I'm looking for are recommendations before I buy an x-main.
    Pictures:
    In my post the y-main I'm talking about is on the left and the x-main is on the top right. The img tag doesn't seem to be working for me so I put the url for the picture below it.
    http://imgur.com/toflbaF <-- picture of back of tv with cover off.
    http://imgur.com/c67macw <-- this is what the ebay x-main looks like. It's missing a cap that the one in my tv has.
    Another thing I'm finding is some people are recommending replacing the y-main as well because it might be what's causing the x-main to fail. Is there any way I can test for this? It'd save me $30-$40 if I didn't need to buy the y-main as well.
    Another thing I thought of was that when I was checking the voltage test leads they start at a normal voltage and then slowly go back down to zero. This is with the y-main hooked up and the x-main unplugged.
  • awyatt2
    • Feb 2012
    • 407
    • america
    Re: 2011 Samsung 51" Plasma clicking no power on - some progress made
    there is a number on the board you go by to ensure compatibility, most start with bn find the number on your board and post it then someone might be able to cross it if another one would work. the rev. letter at the end i.e. bn044237 rev. a usually the revisions are interchangeable. the main part number is usually not.
      You must be careful to avoid getting the 720p X-main for this 1080p set. AFAIK they are not compatible although it may be possible to convert one into the other by swapping some parts.
      • scotty562
        • Jan 2015
        • 5
        This is a close up of the x-main where you can read the model info.
        http://i.imgur.com/Naxwchd.jpg
        It says:
        MODEL NO: 50'DH/DF_XM
        PCB NO: LJ41-09422A
        REV NO: R1.3(11/06/20)
        PBA NO: LJ92-01759A HD
        LJ92-01763A FHD
        There is a barcode that reads TB 764B A2 19M3PJ - BA2.
        Before I do order this do you guys think I'm on the right path? Should I replace the y-main as well just in case that's what took out the x-main or isn't that a big concern?
        Edit:
        I found one that is identical to mine for $25 with the buffer board so that's on the way.
        • scotty562
          • Jan 2015
          • 5
          Thoughts anyone?
          • scotty562
            • Jan 2015
            • 5
            The x-main will be here today. Today is my last chance to decide to get the y-main or not.
            • Sisko
              Onkyo-593 No power and now clicking sound
              by Sisko
              Hi all!!
              Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
              Yesterday, 02:18 PM
            • slimmy182
              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
              by slimmy182
              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
              Looking on google I found this:...
              01-14-2023, 11:55 AM
            • beetle1303
              Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
              by beetle1303
              I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
              On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
              01-13-2025, 08:49 PM
            • mikelu53
              Samsung UN60D8000YF Clicking BN44-0432A
              by mikelu53
              I have a UN60D8000YF with a BN44-0432A power supply and a BN41-01622C main board.
              The set was working then not,then started clicking.
              Wilth the power supply disconnected from the main board I can occasionally get it to power the LED back lights , getting it to stop clicking is luck.
              Checked caps and diodes and mosfets the best I could. When it stop clicking there is 5v and 18v on the connector to the main board.
              A schematic or suggestion would be great.
              01-21-2023, 03:14 PM
            • B0r1s
              Samsung UE49KS7000SXXH - fast clicking sound in standby mode
              by B0r1s
              PSU - BN44-00878A
              Symptoms:
              The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
              A weak clicking sound was coming from the transformer.
              Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
              Progress:
              After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
              01-17-2023, 04:58 PM
