Dead set on 46EX400 Sony Bravia US 110V
  • Martin0101
    • Feb 2018
    • 21
    Re: Dead set on 46EX400 Sony Bravia US 110V
    I have a sony bravia xbr-43x830c the tv is dead. No power at all.. complete dead..no standby led.. what could it be?
      Please start a new thread and make sure to put make and model in the thread name, then up load good clear pictures of the whole back side of the TV showing all the boards.
      The more details we get the more chance of you getting the TV fixed.
      • nomoresonys
        • 12276
        • U.S.
        No standby light on front everything dead usually means bad power supply board.
        • nomoresonys
          • 12276
          • U.S.
          http://www.shopjimmy.com/sony-1-474-...pply-board.htm make sure numbers match.
          • nomoresonys
            • 12276
            • U.S.
            There's some on ebay one of them is 28 bucks, that would be for yours martin0101. If you fix it, don't forget to report back, good luck.
            • nomoresonys
              • 12276
              • U.S.
              #26
              martin0101, do you have good soldering skills, if not I'd just grab that 28 dollar powersupply board from ebay, I know the ebay stuff could be bad but I've had pretty good luck with it. If you want to try to fix the one you have, I guess I would start by checking that fuse think it's labeled F601 but even changing that fuse requires soldering, let us know.
              • nomoresonys
                • 12276
                • U.S.
                #27
                Did you take the back off n check for capacitors bulging at the top, they don't have to bulge to be bad but if they are bulging theyre bad for sure.
                • double_DD
                  How can I be sure that my EC chip is dead?
                  by double_DD
                  As the title suggests, how can I be sure that my EC chip is really dead?
                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                  03-12-2025, 07:47 AM
                • disorder
                  ps5 edm-033 dead after hdmi/usb ports destroyed
                  by disorder
                  hello guys,
                  i need help to repair a edm-033 ps2
                  history : as always hdmi port and usb ports destroyed after unplugged
                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                  so i changed it
                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                  i don't see any projection of liquid metal on pcb.
                  01-14-2025, 12:48 PM
                • zunasthegreat
                  Chieftec GPS-450-AA with dead 20N60C3
                  by zunasthegreat
                  Hello everyone hope all doing well!
                  I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                  09-01-2024, 07:12 PM
                • Beton
                  Finding a dead short component
                  by Beton
                  Hi guys!
                  I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                  So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                  I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                  I have a bench PSU and if I try to inject voltage the voltage...
                  12-10-2021, 01:05 PM
                • FiguringITout
                  MSI Raider GE75 - Not posting, probable dead CPU
                  by FiguringITout
                  Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                  Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                  07-25-2024, 07:27 AM
