Just A General "Does This Look Blown To You??" Question
+ More Options
Posts
  • Michale32086
    • Nov 2011
    • 1453
    I am assuming that if one is not sure whether a cap is blown or not, it's likely a good idea to swap it out...
    Re: Just A General "Does This Look Blown To You??" Question
    Is this a Hitachi plasma power supply? The 100V caps bulging is a common and well known issue with these.
    • Michale32086
      • Nov 2011
      • 1453
      It IS a Hitachi... Seems to work OK which surprised me. I thought for sure those were blown...
      • SteveNielsen
        Retired Tech
        • 2327
        Test them?
        • zomi
          • Nov 2011
          • 505
          Change them, its better to change them now, and have them fail and risk something else being taken out in the process
          • Dang
            • Aug 2013
            • 440
            I have an Hitachi plasma my self, I'm still getting around to fixing it needing a buffer board but from what I remember from my research about these particular caps is when they start bulging, they produce an instability which can take out the lower/upper buffer board, someone somewhere said something about it being a higher voltage is produced but I can't back that idea up, needless to say a change is probably a good idea.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              I was just about to type the same reply. Consider yourself lucky if you have those two caps bulging with both buffers still functional. Every one of these I've encountered with the caps bulging has 1 or both buffers blown. It will happen if the caps aren't changed. Just a matter of time.
              • Michale32086
                • Nov 2011
                • 1453
                Good points all.. Thanx for all the replies. Much appreciated...
                • Shinju
                  • Mar 2014
                  • 1239
                  Can of air and clean that poor sucker out!
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Yea, I already took my air compressor to it.. What a mess..
                    • Michale32086
                      • Nov 2011
                      • 1453
                      Let's say, for the sake of a discussion, that I ignored the great advice I received and left the (apparently) blown caps in and ran the TV all night...
                      Let's further postulate that, when I came in the next morning, shocker of shocks, the TV had died...
                      What boards did I likely blow??
                      I did replace the caps (day late/dollar short comes to mind) but the TV still won't come on.. I hit the master power button and the RED standby light comes on and it immediately goes to BLUE which is labeled ON.
                      I hear a distinct relay CLICK when the master power button is pushed and a faint relay click a few seconds after the light goes BLUE..
                      Nothing appears obviously blown, but I know enough to know that doesn't mean much...
                      Where should I look first??
                      For the record, this is a Hitachi P50T501
                        Buffers and Y-sustain, usually. Maybe Y-sustain survives?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          More tough love.
                          "A man who carries a cat by the tail learns something he can learn in no other way."
                          Mark Twain
                          DON'T FIX IT. Put it up somewhere you can see it daily as a reminder for taking shortcuts and ignoring the advice of posts 5, 6 and 7.
                          --- begin sig file ---
                          --- end sig file ---
                          • mmartell
                            • Oct 2013
                            • 3189
                            Lmao
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Originally posted by retiredcaps
                              More tough love.
                              Mark Twain
                              Touche'
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Never ignore badcaps I learnt that the hard way several years ago, maybe you will learn from this not to ignore them ;(
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Abso-tively....
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    You may not want to use a air compressor as they usually have some oil in the lines. The clean air cans I think are a better way to go.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      They are also usless, I use a small ball compressor that generates air as it runs only cost £10 works better than a tank compressor and crappy cans of air.
                                      • drussell
                                        • Nov 2014
                                        • 144
                                        As long as it is a direct-drive, oil-less type compressor (most small compressors are this type) and the hose has not been used on an traditional oil-lubricated compressor or with a line oiler you should be fine.
                                        Around here the air duster cans are WAY too expensive. A couple cans of that and you might as well buy yourself a small compressor.
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • MrzPdlch
                                          Blown fuses on Gigabyte GTX 980TI 6GB
                                          by MrzPdlch
                                          Hey everyone,
                                          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                          Find some pictures of the actual GPU together with a picture of how it should look like.
                                          I also wonder whther it might be a problem that there...
                                          03-10-2024, 04:14 PM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
                                        • mattx97
                                          HP VICTUS 15-fa1093dx Blown Power IC
                                          by mattx97
                                          I've had a little issue with this laptop. It had a charging issue, so I replaced the charge port and tried the old charger. It was clearly damaged, and the laptop started smoking. So I ordered a new charger and tested again, but no power, and upon further inspection I noticed a power management IC was blown.
                                          I just wanted to know if it was in any way fixable, considering it seems it may have burned layers of the board.
                                          I will attach two photos of the blown one and the seemingly good IC.
                                          Board rev DAG3PAMB8D0
                                          Any help would be...
                                          04-25-2025, 10:30 AM
