Panasonic TH-37PD25 Screen Flicker
    Re: Panasonic TH-37PD25 Screen Flicker
    It might be possible to change the panel setting from the set-up menu, maybe tw2005 knows how on these older sets.
    • CleanSC
      EnthusiastFixer
      • May 2010
      • 91
      Looking thru the service manual (linked in thread) there are some eeprom memory adjustments and such but nothing that states anything different between the two sizes of panels.
      Maybe there's something I can't see there (likely) that you guys can determine?
      Any help would be good. Seller so far is silent.
      Thanks, all.
      Successfully Saved Various TV's and Monitors from the Landfill:
      Acer AL2423W (Fixed in 2010, Still in use today), Panasonic TH-37PD25 (Twice), Panasonic TC-P55GT30 ($100 CL Score), JVC 27" LCD Television
      Repair Equipment: Fluke 88V, Hakko 936
      Skills: Measure/solder at component level. Light IC replacements (Chip Quik)
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        After all of...
        07-13-2024, 08:14 PM
      • TheDando
        MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
        by TheDando
        Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
        10-28-2024, 06:59 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
