LG 42PQ2000 Relay clicking
  • mgibson212
    • Jan 2015
    Chaps,
    I have a LG 42PQ2000 Plasma, power up and the relay starts to click, red standby light flickering on and off.
    Opened the baby up and disconnected the sus boards, problem still there.
    All caps look fine.
    Measured the 5v supply voltage at the micro and it varies, think this is the problem no 5v standby. Any idea for a schematic or components to check.
    Thanks in advance
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: LG 42PQ2000 Relay clicking
    What is the power supply number?
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      I am not going to encourage your laziness I googled for the schematic and found a free one in approx 30 seconds
      • mgibson212
        • Jan 2015
        Pspu-j902a
        eay60696801
        • mgibson212
          • Jan 2015
          Any Idea on which components to test ?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            Have you downloaded the schematic and checked the various stages to see what board maybe at fault?
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              just came across this could be wrong but this could be same issue ?? i would test that diode as mentioned in this thread !
              https://www.badcaps.net/forum/showthread.php?t=49482
              • beetle1303
                Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                by beetle1303
                I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                01-13-2025, 08:49 PM
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
              • TrisHCl
                LED TV Boot loop - UE40F6500SB
                by TrisHCl
                First post...
                I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                I disconnected the main board from the power...
                02-06-2025, 08:42 AM
              • GraphicMan
                Pioneer amplifier A-205 Relay not clicking after a mistake i made
                by GraphicMan
                Hello guys
                Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
                sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
                i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
                on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
                05-05-2024, 06:20 AM
              • meeotch
                Samsung PN64H5000 clicking when powered, then stuck in standby
                by meeotch
                My PN64H5000 shut itself off/on/off a few times in succession last night, then refused to turn on again. When I first plug it in, I get five clicks coming from the power board, and the red standby light on the front goes on and off, as does the little green LED on the logic board. After that, the red standby light comes on after a couple of seconds and stays lit, but the TV will not power on. Confirmed by leaving it unplugged overnight.
                I opened it up, and didn't see any bulging caps, burnt PCBs, or anything else obvious. Tested the two fuses I saw on the power board (one removable,...
                09-27-2021, 02:57 PM
