Panasonic TC-P42GT35 1 Blink break down troubleshooting
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P42GT35 1 Blink break down troubleshooting
    Originally posted by Shinju
    Panel is up and running with SM board out and jumper SC 50 applied.
    Solid red LED, I can hear SS and SC hum.
    Vsus 209
    Vda 60
    SC voltages
    TPVad -206
    TPVSCN -58.7
    SS
    TPVSUS 209
    TPve 134.2
    ok, so sounds like possibly bad SM then .
    • Shinju
      • Mar 2014
      • 1239
      Safe to assume SC board is solid?
      • tw2005
        • Oct 2011
        • 6458
        yes, that's the whole idea of that to help determine how many boards are involved. It at least confirms the voltages on the Sc are in tolerance, can still have image issues but unlikely.
        • Shinju
          • Mar 2014
          • 1239
          Cool, replacement buffer should be here tomorrow. I will update when I get it installed/tested.
          • tw2005
            • Oct 2011
            • 6458
            check it first for shorts before install. did you check yours to confirm it's shorted?
            • Shinju
              • Mar 2014
              • 1239
              I did see a small pock mark on one chip under some of the glue (IC's are covered in it) So I sure this was the cause. I ran out of time to do a check on it but it seems this IC is suspect.
              • tw2005
                • Oct 2011
                • 6458
                well, all I can suggest is check for short between vfg and the buffer outputs on that replacement because i have blown a 5081 SC with 2 shorted buffer boards on a 50" not doing this
                • Shinju
                  • Mar 2014
                  • 1239
                  Never tested a Panny buffer, I am sure its the same as doing other plasma buffers.
                  Do they have test points? I know LG buffers do. I didnt see any on this though.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Thanks TW2005 and Tom66 for your guidance on this too.
                      Test from the screws to each of the pins on the connectors going to the plasma panel.
                      • Shinju
                        • Mar 2014
                        • 1239
                        Got it! Thanks.
                        • Shinju
                          • Mar 2014
                          • 1239
                          So I put my Fluke in Diode mode and Put the + probe on the HV Screw landing and ran the - probe over the connector pins and it seems every chip has a short? I was getting solid beeps all over the connector on each output on each HV screw landing.
                          • tw2005
                            • Oct 2011
                            • 6458
                            dead, very lucky with the Sc board then not blowing.
                            • Shinju
                              • Mar 2014
                              • 1239
                              Lucky and glad the protection circuit was working well!
                              • Shinju
                                • Mar 2014
                                • 1239
                                Panel is up and running with a new SM board installed. Picture looks excellent. I do notice this tv likes image retention if you Switch from bright to dark content like stopping a bluray mid scene. Seems to go away instantly once a signal/picture comes on after.
                                Gonna call it fixed. I have a set of TY-ER3D5MA IR Viera 3D glasses but tin cannot get them to sync to this tv.
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  My 50 always does that from a still image but when in normal no issues and has over 10 000 hrs, I think it is a characteristic as there is never an after image watching TV.
                                  enjoy
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    Awesome!
                                    Thanks again TW2005 and Tom66 and offline Capkid!
                                    • cloo
                                      Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                      by cloo
                                      I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                      It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                      So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                      After doing a factory reset this problem was gone and the picture was back to...
                                      01-06-2025, 06:02 AM
                                    • Andre Gilbert
                                      by Andre Gilbert
                                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                      11-20-2024, 08:52 PM
                                    • jm1234
                                      Panasonic plasma TX-P42ST50 - 6 blinks
                                      by jm1234
                                      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                      I checked that board for any obvious faults...
                                      05-22-2024, 06:59 AM
                                    • orbit417
                                      Panasonic Plasma tc-p55vt50 6 blink error code
                                      by orbit417
                                      Hi All,
                                      Thank you in advance for your advice.
                                      I have a Panasonic Plasma tc-p55vt50 that's about 9 years old and has just recently stopped working :-(
                                      I noticed that when I turn the tv on I hear a click then screen comes on for like half a second then shuts off and the led blinks 6 times.
                                      I did some googling and found several video's on trouble shooting all sorts of blink codes. I finally came across one that showed 6 blink error code but for a different model. It recommended disconnecting the SC board to determine if it was the A board or power...
                                      04-14-2021, 09:11 AM
                                    • CrewmanRedShirt
                                      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                      by CrewmanRedShirt
                                      Hello all,
                                      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                      07-13-2024, 11:02 AM
