Bush LCD37TV006HD inputs changing automatically
  • zx81
    • Mar 2014
    • 118
    Hi Guys can you please help with this Bush LCD37TV006HD problem?
    Pics attached.
    The problem is it will keep switching channels/inputs or go into menus and raise the volume up and down all on its own without any buttons being pressed.
    Here are the voltages:
    BL_ON_OFF - 3.20v
    PMW_DIM - 3.24v
    +12VL - 11.83v
    +5v Stby - 5.5v
    +5v main -5.45v
    styb - 4.74v
    Thanks,
    zx81.
    Re: Bush LCD37TV006HD inputs changing automatically
    Unplug button board and see if fault clears, could be stuck button.
    • zx81
      • Mar 2014
      • 118
      Wow Tom fast reply must have been 60 sec after I posted
      Will check button board right now.
      Cheers.
      • zx81
        • Mar 2014
        • 118
        Removed button board and if i give it a slight twist back and fro I see the set behaving in the same manner but even more directly related to the twisting. What do you reckon dry joints?
        There are only buttons resistors and one cap on the board.
          I've had a fault like this on a Bush made by proview like this set. In that case the strange "parallel port" connector between boards had come loose. It connects the main board to the chassis.
          • zx81
            • Mar 2014
            • 118
            Just flushed out the switched with switch cleaner and so far the set seems to be behaving
            Even when I twist the board the selection stays put. I'll run it for a few hours and keep an eye on it. So far so good.
            Cheers Tom.
            • FlailingEngineer
              Help with Bush Tv (Vestel 17mb95m Mainboard)
              by FlailingEngineer
              Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
              Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
              05-31-2023, 06:52 AM
            • tyler123456
              Need help identifying an IC chip on a Bush DAB radio (BD-1801)
              by tyler123456
              Not sure whether anyone can help but I'm trying to identify the IC chip in the photo below.
              I purchased a faulty Bush DAB radio (model # BD-1801) and identified that an IC chip was blown on it. Unfortunately, I couldn't read the manufacturer name / model number of the IC chip.
              I purchased another (working) BD-1801 so that I could open it up to find out the IC details - but the IC chip details are missing (as you can see in the photo.)
              Given the two huge blobs of solder either side of it I'm guessing it regulates power(?)
              Anyone...
              08-16-2024, 12:51 PM
            • jason123
              Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
              by jason123
              Hello folks,
              New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
              05-27-2025, 07:26 AM
            • _max_
              Hisense H60N5705 automatically switches off
              by _max_
              Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
              Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
              Power cable and HDMI cable checked.
              No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
              So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
              03-07-2025, 06:14 AM
            • pabloroggeri
              Lenovo V310-15ISK - It doesn't work after changing the battery
              by pabloroggeri
              Good guys. I changed the battery to a Lenovo V310-15ISK.
              The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
              When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
              08-23-2024, 12:01 PM
