Insignia NS37D20SNA14 Weird Intermittent LED Backlight
  • bluerider
    • May 2014
    I've got 2 of these Insignia LED TVs with the same problem - LED backlight was off - audio and all other functions were good. Removed LED backlight connector from power supply, re-seated, and backlight now works....for about a week, then same problem. Re-flowed solder around connector and driver components. Again worked fine for a week, then same problem fixed by re-seating backlight connector! Any ideas?
    Thanks!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Insignia NS37D20SNA14 Weird Intermittent LED Backlight
    maybe the backlight cable shorting out?
    • C152Heavy
      Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
      by C152Heavy
      Summary for TL-DR readers:
      • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
      • Have obtained Samsung schematic & service documents - Can upload if helpful.
      • Have read ALL applicable threads
      • C1818 and CP820 replaced as low hanging fruit
      • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
      • VCC pin (18) of PFC...
      01-11-2023, 02:53 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • howardc64
      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
      by howardc64
      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
      • Backlight on, no image
      • Disconnect right buffer board (view from front), left side display comes on
      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
      • Buffer board is pretty simple
      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
      07-11-2025, 04:04 PM
    • szogun
      Weird problem with keyboard backlight in Thinkpad T470
      by szogun
      I`ve bought two T470, both of them has a backlight keyboard, and in one of them (lets name it computer A) it doesn`t work.
      There is no "welcome light up" and no reaction to Fn+Space combination. My first suspect was the keyboard itself, so after checking the connectors, cleaning them na ribbons which didn`t help, i`ve swapped the keyboard as i have second computer (lets name it B)
      From now, things are getting weird.
      Both of keyboards started to work as it should. Welcome light up, switching on and off, changing brightness etc.
      Computer B with keyboard...
      10-02-2021, 02:08 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
