LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
  • selldoor
    Slow Learner
    • 7870
    #81
    Re: LG Plasma 50PK540 Lightning Victim LED Light Relay Clicks On Plug In Nothing Else
    Originally posted by Michale32086
    Looks like a bubble...
    That is ok its just heat - in the other pic the solder joints didnt look good but was just the flash. They look fine
    • selldoor
      Slow Learner
      • 7870
      #82
      OK, I de-soldered the D304...
      When I use the meter in DIODE mode, I get 0L v one way and .20 v with a tone the other way...
      When I use the meter in OHM mode, I get 20K ohm one way and .568M ohm the other way...
      Hooray!!! Id say it is definitely bad
      Any marking on it so we can establish what it is
      EDIT Oh No!!! it isnt I was so excited I misread the .568M ohms - missed the M out
      • Michale32086
        • Nov 2011
        • 1453
        OK So it's not the problem??
        • Michale32086
          • Nov 2011
          • 1453
          Sorry to be distracted.. Had my TV Scrap guy come in and bring me some new toys..
          • selldoor
            Slow Learner
            • 7870
            #85
            ERROR!!! You should have got them to take this one away!!!
            I dont trust/understand the results from your meter perhaps I will have a snooze and see if anyone else can decide if its good or bad - either way
            does it have any marking on it?
            • Michale32086
              • Nov 2011
              • 1453
              hehehehehehe
              Marking like burns or the like?? Nope... The board looks in really good shape...
              It seems I have a penchant for TVs with funky voltage readings..
              https://www.badcaps.net/forum/showthread.php?t=42835
              That one the voltages were ALL good across the board.. Still haven't figured that one yet either. That's the one that prompted me to buy the Rigol..
              I'm thinking I will just replace the power PCB..
              But I really learned a LOT by going thru this one...
              Thanx a bunch to all who replied...
              • selldoor
                Slow Learner
                • 7870
                #87
                [QUOTE=Michale32086;522819]hehehehehehe
                Noooooo! part numbers on the D304 diode?
                • Michale32086
                  • Nov 2011
                  • 1453
                  Oh DOH!!
                  Lemme pull it and I'll check..
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Sb140a
                    1005g
                    • CapLeaker
                      Leaking Member
                      • 8327
                      I don't know guys... if that SB140a diode has a voltage drop of 0.2, to me that is bad. It should have 0.5 to 0.7V drop. Now if that's the little diode that's next to that IC301, chances are good for the IC to be bad too. These sets are known for that to go.
                      • selldoor
                        Slow Learner
                        • 7870
                        #91
                        We have seen that -it is one of the parts in the repair kit. My thinking was that the IC is part of the PFC circuit and as he is measuring almost 400vdc on the BIG caps then the PFC is working so it should be ok, would you/anyone agree with that?
                        What we really need to know is after the Big caps how the VS & VA voltage
                        processed?
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          #92
                          There are so many things here I don't know where to begin. I know you are a beginner and enthusatic to learn, but you must have a bit of thick skin reading my comments/suggestions.
                          None of this is meant as malicious, only to help you. A bit of tough love.
                          1) When you don't know if resistance should be measured with power on or off and that your meter has a diode test function, it is back to multimeter basics 101.
                          You need to learn how to use and interpret readings on a multimeter before continuing. The manual is short and simple and that should be mandatory reading (yes, I read it).
                          More importantly, you need to know how to interpret the readings. Chapter 7 of this book
                          tells you the building block components. It tells you what they are, how they work, why they fail and how to test them. And yes I have read the book from my local library and it is excellent.
                          2) I know you have a new scope, but you should put that aside for now until you get more experience.
                          You should watch some youtube training videos and this one "EEVblog #279 - How NOT To Blow Up Your Oscilloscope!"
                          https://www.youtube.com/watch?v=xaELqAo4kkQ
                          3) If you are going to do more of this repair, you need a better camera with a macro mode and better lighting. You can get an used Canon digital camera with macro mode from craigslist or ebay for around $20. 4MP is sufficient. All my photos on badcaps are taken with a Canon A80.
                          For lighting, since you live in Florida, you have all the lighting you need outside in the sun.
                          4) A SB140a diode is a schottky diode.
                          https://cdn.badcaps-static.com/pdfs/...780a9a5308.pdf
                          As such, it has a low forward voltage drop (straight from datasheet). So a reading of 0.2V and 0L is okay. Most diodes fail shorted.
                          5) When you can't find a training or service manual for your particular TV, try the models below and above it. Since LG makes many 50PK series TVs, you would have found this training manual with a bit of looking around.
                          In it, there is a in-depth section with pictures, describing how the SMPS works and the sequence in which things turn on.
                          It may not be exactly the same as the 50PK540, but it should provide valuable clues.
                          6) So let's review and try to make sense of all the readings. AC detect is 4.66. You have 5V and 17V which means the microprocessor has finished step 1 (see attached pictures).
                          Step 2 is to turn on M_ON (around 3.28V) which supplies 3 voltages including the Va and Vs. This is the key question that selldoor has been asking.
                          If M_ON is not generated (i.e. 0V), then Va and Vs will be 0.0.
                          This is step #7 on page 49 of the diagram.
                          7) Note there is a way to turn on the power supplies automatically, but requires a load to see if the SMPS is good and the main board is suspect. This is described on page 48 under the AUTO GND section.
                          8) I'm not a plasma expert at all, but all SMPS and main board interaction work more or less the same for any consumer electronic device.
                          --- begin sig file ---
                          --- end sig file ---
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Not a problem whatsoever, RetiredCaps.. I know that my ignorance is only surpassed by my eagerness to learn.
                            I'll review all the links and am downloading the manuals right now..
                            Just FYI, there is 0v on M_ON when the unit is plugged in...
                            Thanx again for all the great info and links..
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              #94
                              So what does that tell you?
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                #95
                                I meant to write
                                "Pop quiz, hotshot." What does that tell you?
                                From the movie Speed starring Keanu Reeves.
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Originally posted by retiredcaps
                                  I meant to write
                                  There ain't hardly ANYTHING in this world that can't be addressed with a movie quote!!!
                                  As to what it tells me??
                                  It tells me that I need to study those manuals...
                                  • CapLeaker
                                    Leaking Member
                                    • 8327
                                    I meant to write
                                    I'll be back!
                                    Terminator - Arnold Schwarznegger
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      OK, looking at the diagram is a lot tougher than reading the process on page #50..
                                      But one thing confuses me. Well a LOT confuses me, but one thing stands out..
                                      The page talks about plugging in and powering on.. With this particular TV, they appear to be one and the same..
                                      So, I am going to assume that they are the same, as when I plug the TV in, it appears to go into power up mode..
                                      OK, as I read it, then the TV is powered up, the Microprocessor IC701 is energized and sends a signal (5v) to the RL-ON.. I think I am getting that.
                                      The second signal by IC701 is sent to ML-ON which I am NOT getting..
                                      So, based on that, I would have to conclude that IC701 is wanky..
                                      Howz dat??
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Ahhhhh I think dawn has broken!!!
                                        The problem isn't the SMPS Power Board..
                                        The problem is in the Main Board!!!!
                                        Well, I'll be deeped in sheet!!!
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #100
                                          I meant to write
                                          Bomb on board?
                                          Dont travel by bus?
                                          Thanks retired caps I MAY have got there in the end.
                                          Michale - what is the part number of IC701 ?
                                          • Rensiee
                                            Panasonic TH-50PX8EA Black screen, only relay clicks
                                            by Rensiee
                                            I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
                                            I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
                                            When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
                                            I have measured the voltage in the VSUS line, which...
                                            06-18-2024, 12:58 PM
                                            Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
                                            by momaka
                                            I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
                                            Problem:
                                            Backlight cycles On and Off.
                                            Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
                                            01-17-2019, 11:23 PM
                                          • samtron786
                                            toshiba 46xv555d relay clicks
                                            by samtron786
                                            Hello
                                            The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
                                            2-3 seconds later the relay will click again and only the red LED will stay on.
                                            I would be very grateful for any advice or a little help.
                                            circuit diagram?
                                            Thanks very much
                                            02-04-2023, 04:39 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • jm1234
                                            9V relay temperature 40C
                                            by jm1234
                                            Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                                            I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                                            05-09-2024, 03:03 AM
