Emerson LC401EM3F Backlight and Audio Work, No Video
  • arod
    • Jan 2015
    • 22
    Hello all! I have just started picking up broken televisions and trying to repair them as a hobby. I picked up a 40" Emerson LC401EM3F on Craigslist and have started troubleshooting it, but I am not sure what my next steps should be.
    I was having power supply issues when I first started looking at it. The television would power on for about 2 seconds (with backlight) and then go immediately back to standby mode. For some strange reason, yesterday this problem disappeared and I was able to get the backlight to stay lit. Additionally, I plugged in a source into the HDMI port and the sound was working! However, there is still no video available. When I first picked up the television, I purchased a used but functional digital main board (TCON - A17PHUH). I attempted to swap out the digital main board and there was no effect on the video. The same problem exists (backlight on - sound works, but no video).
    I have the service manual and have been looking through it, but I am lost as to how to troubleshoot at this point. Are there specific points on the TCON board that I can check to ensure it is getting power?
    The service manual can be found at this link .
    Thanks in advance.
  • capkid
    • Oct 2010
    • 1339
    Re: Emerson LC401EM3F Backlight and Audio Work, No Video
    The link you posted brought up a Philips LCD TV's service manual. If the Emerson is identical, check the fuse on the t-con for continuity. If the fuse is bad, you can either replace it or solder another one on top of the old fuse (the latter is easier).
    Edit: I had the same issue a couple years ago with the Philips 40PFL3705D/F7 TV. You can very temporarily install a jumper wire between both ends of the fuse for grins to check the picture. Here's the fuse I installed: http://www.digikey.com/product-detai...5TR-ND/1206513
    LG Plasma Mal-Discharge Correction Service
    • arod
      • Jan 2015
      • 22
      Edit: I had the same issue a couple years ago with the Philips 40PFL3705D/F7 TV. Here's the fuse I installed: http://www.digikey.com/product-detai...5TR-ND/1206513
      As far as I can tell, the two televisions are identical and the parts interchangeable. I apologize in advance, but I cannot find any fuses on the TCON board. I even searched the schematics and did not find reference to them on the digital main board. See attached photo. I was expecting to see something near the two black connectors that are inputs to the board.
      • capkid
        • Oct 2010
        • 1339
        The picture you posted is a bit fuzzy. I would expect the fuse to be near the LVDS connector on the right-hand side of your pic, but it's cut off in your picture.
        • selldoor
          Slow Learner
          • 7870
          If you cant find a fuse or strategically placed 0 rated resistor start by testing the voltage
          accross the capacitors
          • arod
            • Jan 2015
            • 22
            I verified 12VDC on the pins (1-4) that go from the digital main to the LCD module. I presume the fuse you are referring to would be inline with this input. However, I may be looking in the wrong place.
            I have never heard of a 0 ohm resistor. Is this a resistor that has essentially no resistance?
            The schematic for the digital main can be seen on pages 53-58 of the referenced PDF in my first post. A top-level overview of inputs and outputs can be viewed on page 66-68. Any additional guidance is appreciated.
              Can we see the whole back side of the TV?
              That is the main board, not T-CON board.
              http://www.shopjimmy.com/emerson-a17...l-main-cba.htm
              Is the LCD panel this number? LTA400HM09-F05
              T-CON board is under the metal shield top center of the screen, you need to find out if you do have 12V at the SMD fuse on the T-CON board.
              • arod
                • Jan 2015
                • 22
                Sure, see attached photos. The LCD panel is LTA400HM09-F05. I figured that was the LCD display driver board. I will check accordingly. Thanks.
                Edit: Found the fuse and it appears to be blown. I will try jumping a wire temporarily and see what the results are.
                  Ooo, it is one of those LCD panel with integrated T-CON.
                  You will have to take the panel apart to get to that long PCB where the LVDS connector is attached to to see where the SMD fuse is.
                  • arod
                    • Jan 2015
                    • 22
                    Well... After jumping the wire, I believe there was a picture. Unfortunately, I was not in a position to see it when I powered the unit on since I smelled burning and saw a puff of smoke and quickly disconnected the power. There is a reason fuses are integrated in the board...
                      I think you are out of luck on this cheaply made screen not to be repaired.
                      • aaronwt6
                        • Apr 2013
                        • 855
                        • US
                        I'll give you one small piece of good news arod. The power supply you have there is worth around $70-$90 on Ebay. I've sold several recently. Just a heads up before you pitch anything.
                        • ImHereForThePics
                          • Jan 2017
                          • 'Murica
                          I have the same model tv with a similar problem. It has a blue screen and audio but no picture. What could be the problem?
                          • ImHereForThePics
                            • Jan 2017
                            • 'Murica
                            Anybody got any thoughts on this subject?
                            • CapLeaker
                              Leaking Member
                              • 8286
                              Check the LVDS with an oscilloscope and turn on and off the Menu all the time.
                              • Max514
                                Samsung UN55H8000 sound but no backlight no video
                                by Max514
                                Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
                                The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
                                I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
                                • Unplugging the main board cable at the power supply >>> backlights came on.
                                • BLU_ON signal from the
                                04-14-2022, 10:34 AM
                                HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                09-12-2024, 02:00 PM
                              • triplefour
                                by triplefour
                                09-13-2023, 10:43 PM
                              • edugimeno
                                LG 43UK6300PLB has backlight but no video
                                by edugimeno
                                Hi! This TV was ready for the trash so I picked it up before it was thrown away
                                It's pretty new, so I thought I should give it a try. I plugged it in at home and I was expecting blown backlight as most of the TV's that get to me, but in this case it showed backlight with no video at all (no logo no menu no nothing).
                                TV seems internally responsive, drives stdby led red when OFF, responds to remote to turn on and off, but gets no image at all
                                Anything common on these sets to start with?
                                Thanks!...
                                03-26-2024, 03:29 AM
                              • avisonjohn
                                LG 34UM68 backlight and 'chime' on start up, but no OSD or video
                                by avisonjohn
                                I have an LG 34UM68 with board EAX66876002 but it has issues with not working correctly.
                                It powers on, backlight comes on, but there is no OSD shown, and no video shown on the screen.
                                I checked over the board for any obvious visual damage, and everything looked OK.
                                I then took a dump of the main SPI Flash chip.
                                I tried to take a dump from the EEPROM, but it would sometimes read data correctly, and other times would had obvious reading problems.
                                I managed to get a dump from it which somewhat resembled correct data - part of the...
                                10-30-2023, 09:23 AM
