sourcing led backlight strips...
  • hicksvilleshick
    replied
    Re: sourcing led backlight strips...
    Originally posted by lookimback
    You got a part number for the LED strips?
    No. I gotta pull it back apart and see if it's labeled. I know it's a samsung panel LTA460HN05-T02
    but my searches for that have been fruitless.
  • lookimback
    replied
  • hicksvilleshick
    replied
    First off, thank you all for your responses. So much info here that cleared up many things for me.
    Ok I want to say there are more than 16 leds, I've tried looking for them on ebay with no success for my model, that would be ideal honestly, but I just want the damn thing to work. I've got 2 driver boards and it acts the same with both (just flicker of backlight at startup)
    aliexpress is something I'll have to check out and see if it's something I can swing... I've been able to identify it's a samsung panel and all that but haven't had luck finding a source. I could find the whole panel a couple of places, but not just the backlight piece.
    and I'll have to check radio shack too and see what I could do, may do that as a for now. as good as I'm getting at pulling this thing apart and putting it back together... lol
    again many thanks!
  • lookimback
    replied
    Another option is to search ebay for the model number of the TV and then follow the search. Then, you will get an alert when new items are listed and, if you then immediately contact the seller who just listed items and inquire about the LEDs, he may actually have them but didn't think they were worth listing. I have actually done this when I needed parts which sellers never waste their time on and it does sometimes work.
  • saddle_au
    replied
    More than likely, there will be something else wrong on the driver board for the leds.
    Most of these strips that I have pulled out, connect to a board that controls the current going in, not the voltage across the strip. Very simple drivers in cheaper models may just apply a voltage and look at the voltage drop of across a resistor in series with the strip. Almost all of them run some type of pwm signal to the leds that is synced to the tcon or ldvs output to stop stroboscopic (wagon wheel) effects.
    I have shorted a bad led on some in the (recent) past to check functionality, then replaced it from spares. If you have a strip of 8 and reduce it to 7, the voltage change for the driver is not that much greater than the difference between 7 leds going from hot to cold (they change voltage drop with temp) when driven hard.
    If you still cannot make it go and don't have any suitable leds as spares, make a small string of 5 normal 1 amp diodes (1n4XXX) wired in series across the offending led (be careful about not shorting to the metal chassis). Wiring the diodes as a block can be done in a very small space, as shown in the attached picture. If that works and you don't think the missing led is so obvious on the panel, paint the diodes white and leave them there.
    Alternatively, remove a good led from the end of a chain (near the edge of the screen) and put it in the offenders location, then put the leds where it came from.
  • lookimback
    replied
    Or pull an LED and use it on his strip.
  • johnboy1313
    replied
    I have a ton of salvaged LED strips. How many LEDs do you need on the strip? I think I have some with six LEDs and some with eight. You would likely have to make a connector, but it's not impossible.
    replied
    You can use 3.3V Zener 1n4728 1W (1n5333 is 5W) in place to test if that will make it stays on, the Zener will be connected in the reverse polarity of the LED.
  • lookimback
    replied
    Wouldn't it be possible to jump it with a resistor which had the same resistance as the bad LED?
  • electronicsurplus
    replied
    In other words, each Led requires approx 3.2 Volts each to light. So, if you have 20 Leds on a strip this would require 64 Volts, If you bridge or jump one or more of the Leds, the voltage to each Led also changes, which will result in the MainBoard to Signal Shutdown the Power Supply (When there is too much draw or, not enough draw) and, in some cases will burn out more Leds due to excessive voltage. This is a safety feature which was added by Law or Rule due to overwhelming amount of Home Fires as the direct result of Televisions. Therefore, they will go into Safety Shutdown.
    There are some methods to 'temporarily' override this circuit depending on type and model television and, force the TV on.
    Just wanted to add a helpful note
    Aimee
  • CapLeaker
    replied
    Originally posted by hicksvilleshick
    Seeking suggestions on finding either a replacement for my sanyo dp46142 or a place to get a strip that will work to just light it up and plug in separately.
    This tv functions other than the backlight, and while we've found the bad led on the backlight strip, and tried to jump it and those have failed, still just flashes the backlight on startup but it won't stay on...
    Thanks.
    That's because the LED supply is current controlled. One LED not working changes the current consumption. So if one is out, even if you bridge it, the supply is shutting down, the correct current hasn't been drawn. However... you can find these LED's for cheap on these Chinese websites like aliexpress, dx, etc.
  • MagicSmoke
    replied
    Radio Shack has led strips for "project building" I saw them when I got a new tip for my desoldering iron.
    I did not look at them closely for specs though.
  • hicksvilleshick
    started a topic sourcing led backlight strips...
    Thanks.
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • DXseekerMO
    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
    by DXseekerMO
    Hello everyone!
    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
    Yes
    0%
    1
    All backlight strips are the same quality
    0%
    1
    No
    0%
    0
    12-16-2021, 03:58 PM
  • Yanleb
    Vizio M70-D3 4K with dark spots backlight issue
    by Yanleb
    I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
    On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
    I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
    03-22-2022, 01:06 AM
