I am working on a Sony KDL-46HX820 and am getting the dreaded 4 blink error. The screen comes on and everything appears fine for about 5 seconds and then it shuts down and the standby light blinks 4 times. I'm hoping the issue is with the inverter/LED board and not the panel. I've tested the voltages from the psu and all test within range. I'm wondering if there is a trick to these? a common problem on the inverter board that I can search for or a trick to bypass the failsafe?
Sony KDL-46HX820
Re: Sony KDL-46HX820
I had a similar a issue, with a NX720 and I have found some differences between ICs, on the LED driver board.
Next to each IC there is a test point marked Fail 1,Fail 2,... Compare them and see, if you notice any difference between them. -
can can you post some good clear pics. of each board and one of how they are all connected?Comment
4 blinks could be your led driver board, not too familiar with led tvs, hopefully theres an easy way to test led driver board, ok I see tibimakai has a test procedure in post #2.Last edited by nomoresonys; 01-13-2015, 04:11 PM.Comment
some manuals, maybe one is similar to yours. http://www.toms-service-manuals.com/...h=Submit+QueryComment
http://elektrotanya.com/?q=showresul...at2=schematics
Notes: just block diagrams and repair guide.Last edited by budm; 01-13-2015, 05:40 PM.Never stop learning
I had the similiar problem for this model, what I did was to disconnect the t-con cable from the main board, power on, then no shutdown, turn off tv, and connected the t-con cable again. This fixed it. I guess, was the t-con was too hot cause the tv go protection mode. Hope this can give you a hint.Comment
It barely allows power through it long enough to test. After messing with it this morning, I noticed that the top part of the screen goes almost black. It seems like it's probably an internal LED causing the issue. Thanks for the help, but I'm going to scrap it me thinks.Comment
by caseyjay_48I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:27 AM
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... - Loading...
