Samsung LJ92-01737A Test Question
  • jstiene
    • Feb 2013
    • 148
    I have a Y-Main out of a PN42C450 / Insignia NS-42P650A11. It is LJ92-01737A. I was wondering if there is a way to test this board as the screen is cracked and I have sound, but would like to verify that this board is still functional. Are there common failures on this board? And will the cracked screen cause damage to this board?
  • ohren
    Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
    by ohren
    I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
    I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
    The models launched in 2018 and 2019 respectively....
    09-08-2023, 05:24 PM
    09-07-2024, 05:50 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Nicktronic
    Samsung Power Supply Board BN44-00874F
    by Nicktronic
    Hey everyone,
    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
    Anybody...
    03-17-2025, 06:20 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
