INSIGNIA NS-L47Q09-10A: No Sound, No Picture
  • empire1138
    • Mar 2014
    • 14
    I need help. I have a INSIGNIA NS-L47Q09-10A with both no sound or picture. I get the light on the front to light up red when plugged in. The light will change to blue when i press the power button. No flash or flicker on screen. No imagine at all when turn off the room lights and check the screen.
    I have already replaced the power supply board. It was not producing 12 or 24 volts. The new power works. But I'm still not getting any picture or sound. The closest manual for this tv I found was one for the NS-LCD47HD-09 tv. I also unplugged the T-connector board to see if the backlight would come on but nothing at all.
    Voltages:
    CN903 plug
    on/off: 3.117v
    DIM:3.055v
    12v:11.95v
    12v:11.95v
    GND:ground
    GND:ground
    GND;ground
    24v:24.66v
    24v:24.66v
    PS_ON:4.010v
    5v:4.965v
    5v:4.965v
    Next plug:
    DIM:3.055v
    On/Off:3.117v
    Enable: No Wire
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    24v:24.66v
    24v:24.66v
    24v:24.66v
    24v:24.66v
    24v:24.66v
    Next Plug:
    24v:24.66v
    24v:24.66v
    24v:24.66v
    24v:24.66v
    24v:24.66v
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    GND:ground
    Fuse on inverter broad F200:24.64v both sides
    Plug on main broad near top
    GND:ground
    3v3:3.298
    IR:3.292
    B:590.6mv
    R:2.613v
    L_S:No wire
    GND:ground
    IN:3.297
    PWR:3.295
    3v3:No wire.
  • patrax
    • Feb 2014
    • 33
    Re: INSIGNIA NS-L47Q09-10A: No Sound, No Picture
    I have this set NS-LCD47HD-09 that has been on my bench since July I have vertical lines and close to the voltages you have .I have torn my hair out and still cannot get it to produce a picture after replacing so many caps I lost count. Replacement boards have been on in stock alert since July too ,no dice. Another BestBuy throwaway I guess I have had no luck.
      Inverter boards: Check the small black fuse.
      Also check all the white fuses.
      • empire1138
        • Mar 2014
        • 14
        The two white fuse had both 24.66v on each sized.
        That little black fuse had 24.66v on one sided and on the other sized had 1.391v
          That black fuse is the common failure, I have fixed so many of these CMO boards and they are just bad fuse, I used PICO II fuse (you have to bend the legs to install it) and none of the repairs come back.
          You can jump it for testing (or use 1~4.7 Ohm 1/4W resistor), the circuit draws <0.5A.
          • empire1138
            • Mar 2014
            • 14
            Ok. I will try this and update back later. Thank you.
            • empire1138
              • Mar 2014
              • 14
              Thank you. That was it. I was able to pull another smt fuse from another screen(broken panel) to put on this screen.
                So it works now?
                • empire1138
                  • Mar 2014
                  • 14
                  Yes. Works Fine. I was able to watch Netflix and youtube on it. Thanks again.
                  • magicjeep
                    • Apr 2015
                    • 11
                    I have this same tv with the same problem, no picture or sound but the power light works. Nothing looks like its swollen (?), I had a samsung tv do the same thing and I was able to replace the capacitor. Is this the fuse your talking about as a replacement
                    http://www.radioshack.com/4-7k-ohm-1...l#.VTfv7f7F_do
                    If not, could you point me in the direction to purchase one of these fuses? Thanks.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Firstly have you jumped the fuse to make sure that is the issue?
                      • magicjeep
                        • Apr 2015
                        • 11
                        No I haven't, I'm new to this whole fixing tv thing but I figured the tv hasn't worked in months and for $1 it couldn't hurt to try. I've been reading and researching both on this page and the interwebs trying to learn what I can.
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Have a multimeter?
                          • magicjeep
                            • Apr 2015
                            • 11
                            yes I do.
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              Ok set it to Ohms 200 will do.... test the fuse with probe at each side... What is the reading?
                              • magicjeep
                                • Apr 2015
                                • 11
                                sorry my internet went down. The only reading I could get was 69.0
                                  69 Ohms? It should be <1 Ohms so the fuse is bad.
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    Test the 2 white fuses too
                                    • magicjeep
                                      • Apr 2015
                                      • 11
                                      ok. One white fuse is reading .3, the other white fuse is giving me a hard time getting a reading, like the small black fuse. The numbers flash, 84.3, 69.4... and then disappear. I did test the black fuse while the tv was powered on and all of a sudden the picture came on while the probes were on it. Don't know if that means anything.
                                        More likely to be that commonly fail small black fuse.
                                        • jose6326
                                          Insignia Ns-l22x-10a no picture only sound
                                          by jose6326
                                          When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                          When i was removing the back cover i heard a rattle.
                                          Removed the metal plate and the heat sink was off (see pic)
                                          would this cause a no picture/image issue?
                                          What is used to put back the heat sink
                                          07-30-2024, 11:03 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
