LG47LC7DF power supply issue- pics and some voltages
  • links56
    • Jan 2015
    • 11
    Re: LG47LC7DF power supply issue- pics and some voltages
    So if I unhook the connector P201 then take the on/off wire out of the connector, then plug it back in, the red light on the front will light up. If I measure the voltage on the wire I removed from the connector after hitting the on button it will read 2.3 volts, after several minutes it will go to 3.3 volts on its own. Then if I push the wire back into the connector, it will turn the tv on and it all works great. Shut the tv off with the power button and then it goes back to the beginning of the problem again?
    What is responsible for regulating the voltage going to the on/off pin? Unfortunately my dsl has been down so I have to try to read the schematics on my cell phone, it's hard for me to trace.
    Thanks again.
      The on/off signal from the main board is done through a transistor that is turned on and off
      <1V on the ON/OFF pin = OFF
      >2.50V on the ON/OFF pin = ON
      It is not regulated Voltage, as long as it is <1V (it can move up and down from 0~1V it will be OFF, same if the ON signal is >2.5V (it can be varied up and down but as long as it more than 2.5V that will be consider ON.
      You can put the resistor may be 4.7K on that ON/OFF WIRE and Ground from the main board and monitor the DC voltage on that resistor when TV is off and when power switch is activated to see if it can handle 4.7K Ohm load.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
      • lp20th
        Samsung Plasma TV Power Supply Issue
        by lp20th
        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
        11-28-2023, 10:28 AM
      • gurj1979
        Motherboard issue - all voltages OK but no display
        by gurj1979
        I've got a couple of Intel and AMD boards which turns on fine, all voltages at all coils are present, but there is no display.
        I guess this like Code 00 issue.
        I've tried a couple of good CPU's and working Graphics Card.
        PCH has been replaced too. On one Intel board I have even replaced the CPU Socket.
        The CPU's don't get hot, but gets a bit warm.
        All RAMs are good.
        BIOS is good on all.
        PSU is Antec 1000W and I use this for on more powerful boards and 2080Ti cards, so this isn't the issue.
        What's the issue when motherboards have this issue ?
        02-24-2023, 05:53 PM
      • handsworth
        TCL 43S431 Backlight issue or Power Supply
        by handsworth
        I was wondering if anyone else has come across this problem. What was the problem?, and was it solved. I recently picked up 2 of these tvs and both initially diagnosed as bad backlights. When turned on, the backlights flash the red logo screen. Sound and an image is clear using a flashlight. So I buy 2 sets of leds. When they arrive I take one tv apart and test the leds before removing them. OMG they all work. but I put the new ones in anyway. So I think its the power supply. I swap PS from one to the other and same results. Now here is the issue and really confused me. I reset the tv using...
        10-16-2024, 04:29 PM
