Vizio V320EL Power and Backlight Good, But No Picture - Please Help
  • TubeJunkie
    • Oct 2012
    • 107
    Hi, I have a Vizio E320VL LCD TV. It powers on fine. Backlight is lit, but no picture, and no on screen menu display. Nothing on the screen at all. I've replaced or checked all caps on both boards, with no avail. Also checked the tiny fuse on the main board for continuity. At one point I had sound while hitting the input button. Any ideas? Thanks in advance for your help.
  • TubeJunkie
    • Oct 2012
    • 107
    Re: Vizio E320VL Power and Backlight Good, But No Picture - Please Help
    I misread this Vizio model number. It's actually: E320VL.
    I went ahead and took some voltage readings and pic.
    Starting at the bottom of the picture and working up. Not counting the first black wire:
    1. Brown 5.33v
    2. Red 5.33v
    3. Orange -0.02v
    4. Yellow -0.02v
    5. Green -0.02v
    6. Blue -0.02v
    7. Purple 12.35v
    8. Gray 12.35v
    9. White 12.35v
    10. Black 2.98v
    11. Brown 3.29v
    12. Red 0.0v
    13. Orange 3.07v
    Power board is a Delta DPS-165DP
    0500-0407-1010
      Re: Vizio V320EL Power and Backlight Good, But No Picture - Please Help
      There are labels for each one of those pins, what are they? It will make it easier to know which signals are not working.
      But at this point you should check the DC Voltage at both end of the surface mounted fuse on the T-CON.
      • TubeJunkie
        • Oct 2012
        • 107
        I've updated with corecct label now. Thanks
        Wire Reading Labeled
        1. Black 5.33v = +5.25 VSB
        2. Brown 5.33v = +5.25 VSB
        3. Red 5.33v = +5.25 VSB
        4. Orange -0.02v = SGND
        5. Yellow -0.02v = SGND
        6. Green -0.02v = SGND
        7. Blue -0.02v = SGND
        8. Purple 12.35v = 12V
        9. Gray 12.35v = 12V
        10. White 12.35v =12V
        11. Black 2.98v = PSON
        12. Brown 3.29v = I-On/Off
        13. Red 0.0v = LAMP
        14. Orange 3.07v = DIM
        0500-0407-1010
          They all good that is why the backlights inverter is working.
          You need to check the DC Voltage of the T-CON board next.
          • DLinkOZ
            • May 2013
            • 238
            Sounds goofy, but I had this same TV with no picture. Reseating the LVDS cable got it back up and running. That's the rare easy fix, but the simple free things should be looked at first.
              There are more than one version of this model, your TV may not have separate T-CON board.
              We need good clear pictures of the whole back side of the TV to what you have.
              http://www.shopjimmy.com/catalogsearch/result/?q=E320VL
                • 12276
                • U.S.
                really need that tcon fuse reading budm requested.
                • TubeJunkie
                  • Oct 2012
                  • 107
                  This TV only has the two boards. I guess the T-Con is made into the main board. There is a narrow board long board thats made onto the top ofthe panel itself. Here are the pics.
                  I also tested DC voltages on both sides of both little fuses on the main board, and they are right on, and both sides read the same.
                    Check fuse TF1 on the main board to see if you have Voltage at both ends.
                    The two white fuses are for the 5VSTBY, and for the switched 12VDC.
                    • TubeJunkie
                      • Oct 2012
                      • 107
                      budm Tested TF1 as you requested. I have no voltage on either side of TF1. What does this mean?
                        Do you see that 8-pin device just above the FUSE? That is the power MOSFET which is used as a electronics switch to supply the Voltage to the fuse, the MOSFET is turned on (T-CON on) the by the processor of the main board, so the processor is also not sending the signal to turn on the T-CON either, no surprise there.
                        • TubeJunkie
                          • Oct 2012
                          • 107
                          Yes budm, I see what you're refering to. So, I guess I should just find another main board?
                            At this point, yes.
                            It can be the EEPROM problem that needs to be replaced.
                            http://www.shopjimmy.com/catalogsear...q=Vizio+E320VL
                              • 12276
                              • U.S.
                              ok, my bad, couldnt tell, didnt see any pics.
                              • TubeJunkie
                                • Oct 2012
                                • 107
                                At this point, yes.
                                Well, I greatly appreciate your help and Thank You for sharing your knowledge. SJ was sold out, but I found a couple on the bay for around $50. Can't get it right now, but I'll keep you posted, when I do. Happy New Year!
                                  Careful if you did not get from SJ since it can have EEPROM problem.
                                  • Mgiffune
                                    by Mgiffune
                                    06-09-2024, 10:28 AM
                                  • ggil44
                                    Vizio M65-E0 No Picture, No Sound
                                    by ggil44
                                    Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                    09-03-2024, 08:30 PM
                                  • maricm
                                    Vizio m65-c1 picture flashing on and off on the screen
                                    by maricm
                                    HI all,
                                    hope someone point to the possible issue before I start buying replacement parts.
                                    Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                    Backlight stays on all the time,
                                    Sound works fine.
                                    screen keeps changing form black to full picture in about 1sec intervals.
                                    Picture looks fine with no visible artifacts.
                                    I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                    Disconnecting left and right ribbons on...
                                    11-25-2023, 06:32 PM
                                  • Fly_Among_Stars
                                    VIZIO E70-E3 Half picture with half TCON
                                    by Fly_Among_Stars
                                    I have a VIZIO E70-E3.
                                    Symptoms: Black screen, no picture, but LED backlights are working.
                                    I probed the power board and voltages are as listed on the board.
                                    Main board appears fine, too.
                                    I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                    There are two separate ribbon cables feeding the LCD.
                                    If both are connected, the screen is black.
                                    If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                    04-24-2023, 08:20 PM
                                  • Tr0ll
                                    by Tr0ll
                                    Original T-con:
                                    First replacement T-con:
                                    10-07-2023, 07:48 PM
