panasonic viera 42" rolling lines down screen
  • Bikemech
    • 14
    • Uk
    Re: panasonic viera 42" rolling lines down screen
    ok so is it just worth changing the A board for another one, rather than trying to fix it?
    when you say heat, you mean like a heat gun on the undeside where its soldered?
    and sorry but A board is the main one on the right hand side bottom, with the hdmi and other sockets on it?,
    • Bikemech
      • 14
      • Uk
      where eould be a good place to get a replacement board,
      someone mentioned johns parts or something like that?
      • tw2005
        • Oct 2011
        • 6457
        I Can't really say but first thing would be to identify the correct board and revision, then google away
        • Bikemech
          • 14
          • Uk
          i do that by the codes on the board itself i presume ?
          • tw2005
            • Oct 2011
            • 6457
            varies from region to region but either it will be the board number TNPHxxxx Rev xx as per a legend on the board or it may be stamped or white sticker could start with TXN/xxxxxxxx
            Looks like Shopjimmy in the US has some.
            http://www.shopjimmy.com/panasonic/tx-p42s20b
            TNPH0845LB
            TXN/A1LHUB
            Certainly weird how this has a separate tuner board.
              Separate tuner is probably for Freeview HD, which is OTA HD tuner. Pretty nice feature to have, probably a bit of a last minute thought.
              • Bikemech
                • 14
                • Uk
                #27
                Originally posted by tom66
                When I post depends entirely on when I have the time...... Tw will probably chip in later with additional info... I reckon this is an A board fault, you should access the service menu and use the test patterns feature.
                Not sure what it is for this 2010 model but 2008 is this:
                Hold VOL- on TV and press 0 on remote three times.
                Wait for menu to appear (takes a few seconds)
                Press "red" on remote a few times to select different patterns, note which, if any, are affected.
                Ok did this and every step/ colour/ pattern are affected by the rolling lines Dow the screen, they do not go away at all!!
                Does this help any?
                  Well, it doesn't eliminate anything unfortunately, it could be the main board or something else, going by the symptoms alone it looks a lot like a main board fault, difficult to determine exactly where.
                  • Bikemech
                    • 14
                    • Uk
                    #29
                    So it's probably best just to change it completely?
                    • Neelix
                      • Oct 2013
                      • 145
                      • South Africa
                      #30
                      Could you check the monitor out picture? If the lines appear in the monitor out picture also, then it confirms the A board is faulty. Would you be able to get the correct service manual and do you have equipment to replace BGAs or know somebody that does? If not, then getting another A board would probably be your best choice
                        Most TVs supporting "monitor out" (unless they directly support DTV or HDMI out) aren't reprocessing the signal, they're just re-routing the signal internally, so it's hard to say if that would confirm any particular issue.
                        • Bikemech
                          • 14
                          • Uk
                          #32
                          Sorry no I don't think it has monitor out, and I have no way of doing ball grid array re work or replacement, (googled BGA lol), is it possible it is just one bad IC on the A board causing the problems? A mean is there one main one or a few?
