panasonic viera 42" rolling lines down screen
  • Bikemech
    • Dec 2014
    • 14
    • Uk
    Re: panasonic viera 42" rolling lines down screen
    ok so is it just worth changing the A board for another one, rather than trying to fix it?
    when you say heat, you mean like a heat gun on the undeside where its soldered?
    and sorry but A board is the main one on the right hand side bottom, with the hdmi and other sockets on it?,
    • Bikemech
      • Dec 2014
      • 14
      • Uk
      where eould be a good place to get a replacement board,
      someone mentioned johns parts or something like that?
      • tw2005
        • Oct 2011
        • 6457
        I Can't really say but first thing would be to identify the correct board and revision, then google away
        • Bikemech
          • Dec 2014
          • 14
          • Uk
          i do that by the codes on the board itself i presume ?
          • tw2005
            • Oct 2011
            • 6457
            varies from region to region but either it will be the board number TNPHxxxx Rev xx as per a legend on the board or it may be stamped or white sticker could start with TXN/xxxxxxxx
            Looks like Shopjimmy in the US has some.
            http://www.shopjimmy.com/panasonic/tx-p42s20b
            TNPH0845LB
            TXN/A1LHUB
            Certainly weird how this has a separate tuner board.
              Separate tuner is probably for Freeview HD, which is OTA HD tuner. Pretty nice feature to have, probably a bit of a last minute thought.
              • Bikemech
                • Dec 2014
                • 14
                • Uk
                #27
                Originally posted by tom66
                When I post depends entirely on when I have the time...... Tw will probably chip in later with additional info... I reckon this is an A board fault, you should access the service menu and use the test patterns feature.
                Not sure what it is for this 2010 model but 2008 is this:
                Hold VOL- on TV and press 0 on remote three times.
                Wait for menu to appear (takes a few seconds)
                Press "red" on remote a few times to select different patterns, note which, if any, are affected.
                Ok did this and every step/ colour/ pattern are affected by the rolling lines Dow the screen, they do not go away at all!!
                Does this help any?
                  Well, it doesn't eliminate anything unfortunately, it could be the main board or something else, going by the symptoms alone it looks a lot like a main board fault, difficult to determine exactly where.
                  • Bikemech
                    • Dec 2014
                    • 14
                    • Uk
                    #29
                    So it's probably best just to change it completely?
                    • Neelix
                      • Oct 2013
                      • 145
                      • South Africa
                      #30
                      Could you check the monitor out picture? If the lines appear in the monitor out picture also, then it confirms the A board is faulty. Would you be able to get the correct service manual and do you have equipment to replace BGAs or know somebody that does? If not, then getting another A board would probably be your best choice
                        Most TVs supporting "monitor out" (unless they directly support DTV or HDMI out) aren't reprocessing the signal, they're just re-routing the signal internally, so it's hard to say if that would confirm any particular issue.
                        • Bikemech
                          • Dec 2014
                          • 14
                          • Uk
                          #32
                          Sorry no I don't think it has monitor out, and I have no way of doing ball grid array re work or replacement, (googled BGA lol), is it possible it is just one bad IC on the A board causing the problems? A mean is there one main one or a few?
                          • Stanley1843
                            Screen Display Vertical Multicolor Lines
                            by Stanley1843
                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                            06-29-2024, 11:54 AM
                          • jeyoung12
                            Samsung QN50Q60t lines on screen
                            by jeyoung12
                            Hi all
                            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                            So....i don't know what end of the C ribbon to work with...
                            02-26-2024, 10:38 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • kdaniel
                            Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
                            by kdaniel
                            As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
                            There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
                            After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
                            Left...
                            11-16-2022, 09:23 AM
                          • Chrissygizmo
                            Sony KD-55XG9505 lines on screen problem
                            by Chrissygizmo
                            Hello again everyone,
                            This is my latest mission, to try getting this Sony tv back to normal working order…
                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                            02-19-2025, 11:31 AM
