vizio e320vl firmware needed
  • KevinCro
    • May 2014
    • 104
    Hello all. I have a vizio e320vl that i need to update the firmware. I can't find any place to download it except for a few sites that I'm certain are full of malware. Does anyone have the firmware download for the mentioned model? I called vizio support and they were not much help and the website does not have a download page for the tv. Any help is appreciated.
  • Daniel Larsson
    Firmware file for Marantz NR1501 needed
    by Daniel Larsson
    I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
    After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
    The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
    The content of these seems to be useless as far...
    05-23-2025, 04:11 AM
  • neo2010
    Lenovo X1 Carbon Gen 2 Touchscreen Firmware needed
    by neo2010
    I accidentally flashed the wrong firmware to my Lenovo Laptop Touchscreen. Now it is not recognized anymore in Windows 10. With Linux, I get the Device Listed as ELAN 04f3:000b USB device. I have modified the original Lenovo Flash Tool and tried other Firmware bin files but without success.
    The screen is the WHQD version. Can anyone provide a firmware bin file to reflash the touchscreen controller? As it seems that the controller is in recovery mode.
    Thanks in advance
    05-23-2024, 08:04 AM
  • gkoukoul
    TV Felix FXV-4221 - firmware needed
    by gkoukoul
    Hello!
    I have a Felix TV that turns on, shows the "FELIX" logo then shows a "WISDOM SHARE" message and doesn't do or respond to anything else.
    I'm assuming a firmware flash will fix it.
    I can't find the firmware file though, anyone has it please?
    11-12-2024, 12:02 PM
  • Sam Scarbo
    Blomberg DV17600W laundry dryer MCU firmware needed. Please help!
    by Sam Scarbo
    I'm helping my brother to fix his Blomberg laundry dryer. He called a repair guy to have a look and the repair guy said the control board is faulty. They said the replacement board costs $400. Too expensive! 😨 My brother asks me to take a look. He has checked the door switch and thermal fuse, etc., and those seems fine.
    After plugged to mains, there is no display. There is just a clicking sound from the buzzer, like one click per second. No other response.
    I suspect the firmware inside the MCU (ATMEGA64A) got corrupted. Can someone in this forum by any chance provide...
    07-21-2024, 05:24 PM
  • jason123
    Vizio D50-F1 - Can't update Software / Firmware
    by jason123
    Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
    I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
    I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
    08-15-2021, 06:48 AM
