samsung LN-T4069F sound good, blinking video
  • ilikesteel
    • Jul 2012
    • 284
    • usa
    Hi guys. I have two samsung's driving me crazy. this one, the LN-T4069F is about this thread. this is my bedroom TV. within the past year, when the set was turned on, occasionally the sound came on but no video. this happened a few times. then all of a sudden turning the set on one day, and there was video and sound like normal.
    the set worked that way for months. then again just recently, a few days it would exhibit the same symptoms again, turn on, sound ok, no video.
    after working properly for a few months afterwards, today, turn on, sound ok, now I have blinking video! seems to blink on/off every .5 seconds. sound is ok, no intermittent sound as the video blinks on and off, sound is solid.
    I have not pulled the set apart at this time to get board pics, etc. from my description, does anyone have a good guess as to what is causing this problem?
    a side note, the other samsung is a LN-T4671F. I posted a thread about it months ago. BUDM and a few other forumites gave me some suggestions it also has the same issue, but is so intermittent, perhaps 1 out of 50 times of turning power on, the set will come up normally and will stay on normally as long as the set is not powered off. most of the time, turn on, sound is great, no video but there is a backlight on, screen is kind a grey, but you can see the backlight from the back of the set with the boards exposed.
    Voltages on the LN-T4671f were all good. I was able to check them when the TV didn't work properly and then again when the TV came on normally. voltage readings were the same when the TV worked or didn't work.
    do the samsung models, beginning with LN-T have an inherent problem with the intermittent video, but ok sound?
    sorry to have rambled. I hope someone can point me in a positive direction.
    ilikesteel
  • nomoresonys
    • 12276
    • U.S.
    Re: samsung LN-T4069F sound good, blinking video
    could be a bad capacitor problem, maybe try heating with hair dryer on different sections of boards to see if theres any change, to try to isolate the problem area, dont melt anything just add some heat, thats if you dont see any obvious capacitor issues, might also try the freeze spray or air duster.
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      nomoresony's,
      I can try that. what board would you think might cause this problem.
      thanks
      • ilikesteel
        • Jul 2012
        • 284
        • usa
        Update for Monday morning 12-29-14. the TV turned on this morning and came up normally great picture and sound.
        • nomoresonys
          • 12276
          • U.S.
          not sure, could be a borderline capacitor maybe?
          • gl4709
            Samsung un55cu7000d with backlight and sound No Video / Picture
            by gl4709
            I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
            01-23-2025, 06:21 PM
          • Max514
            Samsung UN55H8000 sound but no backlight no video
            by Max514
            Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
            The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
            I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
            • Unplugging the main board cable at the power supply >>> backlights came on.
            • BLU_ON signal from the
            04-14-2022, 10:34 AM
            09-07-2024, 05:50 AM
          • alro7779
            Samsung UN55MU6103F video problem; has colored stripes on the display
            by alro7779
            Hello, everyone!
            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
            09-27-2025, 11:29 PM
          • soeren
            A2442 - No sound over internal speakers and no video playback
            by soeren
            I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
            All happened after the battery ran out of power overall several days when I was on vacation.
            I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
            07-26-2024, 01:24 AM
