What would cause all the back lights to go bad all at once on this tv. Have good voltage from power board to leds. I have removed the back light strips and all fail to light using micrometer diode test. All positive connections on strips fail continuity test also. Lamp holder is a 6637L-0021A and led strips are 6916L-1272A, 1273A, 1276A & 1241A. I believe that replacing these will fix the tv, but just curious why all would fail at once. Any help is appreciated.
Toshiba 50l1350u dead backlights
Re: Toshiba 50l1350u dead backlights
Look for cold solder joints and cracks on the backlight system. Perhaps a loose connection is preventing power to it.Comment
Hello Andrew thank you for your answer where can I locate the Backlight on this TV since I can only see the main board T-con board and power supply is it underneath of the lcd glass ? one other question those this tv have an invert board combine with an other board or backlight combine with an other board ? Thank you so much .Comment
Before you are all game and tear into the panel, how about you turn the TV on and probe the BLon pin against chassis GND. This way you know if the main board is turning on the backlight first place. Then probe the L1 pin pair and the L2 pin pair. See what that gives first.Comment
Hello CapLeaKer I got the tv open how can I probe the BLon pin against the Chassis ? if you can give me an idea where is the BLon pin and the L1 and the L2 pin on what board would I be working on thank you a lot ! witch one its the BLon pin ?Comment
Everything is on the power supply. There are 2 connectors, one big one and a small one. Next to it there should be little chart that explains what pin has what function. Put the DMM into DC put the black probe to chassis GND or to a GND pin and the positive lead to the BLon pin. On the L1 and L2 pair, that is the backlight. There can be a 100V DC depending on size. Of course the TV has to be on.Comment
I open up this tv and notice 6 lapms but 0nly 3 of them are working so I took two wires from a good one and test one of the bad one and it came on so now I know all the lamps that are not working are good and look careful at the led lamp board there is no cracks so seems like I have a failed power supply do any body know if this power supply its fixable ? is it the capasitors or diodes ? any help thank you!!Comment
I open up this tv and notice 6 lapms but 0nly 3 of them are working so I took two wires from a good one and test one of the bad one and it came on so now I know all the lamps that are not working are good and look careful at the led lamp board there is no cracks so seems like I have a failed power supply do any body know if this power supply its fixable ? is it the capasitors or diodes ? any help thank you!!Everything is on the power supply. There are 2 connectors, one big one and a small one. Next to it there should be little chart that explains what pin has what function. Put the DMM into DC put the black probe to chassis GND or to a GND pin and the positive lead to the BLon pin. On the L1 and L2 pair, that is the backlight. There can be a 100V DC depending on size. Of course the TV has to be on.Comment
Looks like supply to the LEDs is not working. I would just go ahead and change the Power board.Comment
Read my post 7 againI open up this tv and notice 6 lapms but 0nly 3 of them are working so I took two wires from a good one and test one of the bad one and it came on so now I know all the lamps that are not working are good and look careful at the led lamp board there is no cracks so seems like I have a failed power supply do any body know if this power supply its fixable ? is it the capasitors or diodes ? any help thank you!!Comment
Yes. Please revisit the CapLeaker Post #7. What voltages are you getting??Comment
Hello I know what is my problem with this tv I have a bad lamp basically half of this lamp its good the other half its bad the way I found out I connect a wire from the + to the - pin in the middle of the lamp and all lamp came on except the rest of the lamp so now I need to order the part 6916L-1276A thanks for your help !!Comment
Hello I have this model# Samsung
pn42c450b1dxza i am haveing the same problem with this model ! i have a black screen no picture at all i have sound even if its dark in the room any Help thannk you? i am haveing a problem with ! i have a black screen no picture at all but I have sound I replace the T-con board but that didn't fix my problem thank you![/QUOTE]Comment
With the back cover carefully removed check to see if the backlights are OFF. Most likely they are. Where are the supply wires for the backlights coming off? The power board or another board. Check the voltage on the BL-ON pin. Perhaps you should open a separate post with your TV Model No. You would get quicker responses.Comment
this is what i have does these voltages seem right?
MY BOARD
L2- =1.01V
L2+ =79.8V
L1- =14.88V
L1+ =79.8V
PWM =0.229V
5.1V =5.129V
BL_On/Off =3.236V
Power_TV =3.291V
AC_Detect =3.502V
5.1V =5.128V
GND =0.001V
12V_LNB =0.001V
GND =0.002V
12v_AUD =12.49V
GND =0.001V
GND =0.001V
12VDC =12.48V
12VDC =12.48V
12VDC =12.48V
NEW BOARD
L2- =1.188V
L2+ =77.2V
L1- =12.82V
L1+ =77.2V
PWM =0.229V
5.1V =5.165V
BL_On/Off =3.235V
Power_TV =3.291V
AC_Detect =3.530V
5.1V =5.165V
GND =0.001V
12V_LNB =0.013V
GND =0.002V
12v_AUD =12.56V
GND =0.002V
GND =0.002V
12VDC =12.55V
12VDC =12.55V
12VDC =12.55VComment
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
by jesteraceHi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
However, I am in a dilemma.
I tested the backlight outputs with the lights disconnected... -
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
- Loading...
