Wanted, Control-Board Firmware for LG 42G2#### panel
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Hoping someone has a copy of the F/W for this set.
    I have the L.G. SVC Kit to download to the control-board, and many files of F/W.
    --However, I dont have the file for the 42G2#### series panels....
    According to research, there appears that there are 3 versions of the F/W, so if you have any copy at all, send me a message......
    Thanks....
    TELEFIX
    Re: Wanted, Control-Board Firmware for LG 42G2#### panel
    Out of interest, why do you need it? Maldischarge?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Yup--Mal-Discharge, not the spotting, but on highlights/medium-lights and certain colours....
      All voltages OK and the usual adjustments dont cure it well enough....
      TELEFIX
        Sorry, best I have is this...
        http://www.toms-service-manuals.com/...&Search=Submit
        Only has up to 42G1 firmware.
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • thesame
          Dump/Firmware needed TV Vinchi LED-VC24E16D Board T.EME380.61 panel CX240LEDM
          by thesame
          If someone can help with a firmware i would really apreciate....
          09-25-2024, 08:30 AM
        • Storyteller12
          QN55Q60R Service Menu Panel Help
          by Storyteller12
          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
          01-13-2024, 01:57 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
