(CRT)QUADRO CTV-5525 ,Horizontal white lines problem
  • microcont
    • Nov 2013
    • 35
    • Croatia
    Hello, so I have this TV with the problem that on screen are these white lines .. so i tired to look around board but everything seems okay except some bad soldering joints that was resolder but problem is still here, this is not a priority repair i just what to learn something about CRT TV's. About CRT TV's I know only basic working principle from school. So thanks guys i can post more pictures of board,electron gun and so on.
    Re: (CRT)QUADRO CTV-5525 ,Horizontal white lines problem
    This is usually caused by a fault in the circuit that blanks the electron beam during the vertical re-trace stage of the CRT scanning.
    • microcont
      • Nov 2013
      • 35
      • Croatia
      So fault is probably in that circuit , where to find that part of circuit and is there any special part to look for?
      • freakaftr8
        • Oct 2012
        • 3743
        you could always check and see if the screen adjustment on the back of the TV if it's accessible has not been tampered with more known as G2 adjustment I've seen people over drive these because the CRT is starting to get weak.
        • microcont
          • Nov 2013
          • 35
          • Croatia
          on the flyback transformer are two knobs for adjustment focus and brightness
            Try the brightness control first.
            • Ltank
              • Jun 2013
              • 776
              I believe your horizontal frequency is too high. Check the oscillator circuit. Should be 17,750 hz if I remember correctly.
              • microcont
                • Nov 2013
                • 35
                • Croatia
                try to adjust knobs on flyback transformer no results only changing brightness and sharpness, huh,i can't measure frequency because i dont have an oscilloscope :/ i can change parts in oscillator circuit
                • R_J
                  • 9627
                  Look for a capacitor near the flyback or near the vertical circuit. should be a low value 2.2 3.3 10 or 22 uf at a high voltage 200, 250 volts, It won't look bad but most likely is, ther may also be a couple bad caps arount the vertical output that could be weak
                  Looks like it could be C706 1uf 250v
                  • microcont
                    • Nov 2013
                    • 35
                    • Croatia
                    at the output to the electron gun board it is 10uF 250V. It is very dusty trying to clean that..
                    • microcont
                      • Nov 2013
                      • 35
                      • Croatia
                      vertical IC is:
                      HTML Code:
                      http://www.rem-tv.odessa.ua/datasheets/v_def/LA7840.pdf
                      • R_J
                        • 9627
                        It looks like this might be a closer diagram, the dust won't cause the problem. on this diagram its c303
                        • microcont
                          • Nov 2013
                          • 35
                          • Croatia
                          I change that cap, but no results still is the same screen with lines as before
                          • microcont
                            • Nov 2013
                            • 35
                            • Croatia
                            TV works after testing resistor R322 0.68Ohm to find out that it is an open circuit , and i replaced R322 with new 0.51Ohms. It works fine.
                            Thanks guys for help
                            • R_J
                              • 9627
                              If that cap C303 was bad, then there may have been excesive current through d305 causing R322 to open, Bet the cap was bad I have replaced this cap. in more sets than I could count for having retrace lines in the picture.
                                Yep, resistors rarely fail without obvious cause.
                                • microcont
                                  • Nov 2013
                                  • 35
                                  • Croatia
                                  Now it is new C303 and R322 hehe thanks for the explanation , i will remember that fault on TVs
                                  • thstuff
                                    SONY BRAVIA XBR-55A8H - White horizontal lines / red LED flashes four times
                                    by thstuff
                                    This "free from a friend who was going to recycle it" SONY BRAVIA XBR-55A8H arrived with the bottom center RED LED repeating a four flash pattern. It was treated with kid gloves and was reported to have "just gone dead" and the OLED panel has no dents in the metal frame or cracks.
                                    Thread https://www.badcaps.net/forum/showthread.php?p=1091829 helped in proceeding as follows:
                                    1) Unplugged, then plugged set in while holding the remote VOL- and Power to factory reset.
                                    2) Waited 30 seconds, then pressed remote Power button and "Select language"...
                                    01-30-2023, 05:01 PM
                                  • EazyBone
                                    75r648 TCL 8K Mini LED White Horizontal Lines
                                    by EazyBone
                                    TV turns on, lights work sound works.
                                    TV shows white/gray horizontal lines across the whole screen as shown in picture. TCON is getting 12v at fuses, VCC 12v.
                                    First experience with 8k and mini LED. Does this picture tell you anything?
                                    Apparently a "certified TCL tech" looked at this TV before I got it free and said it's a Tcon issue but said he couldn't be sure and wrote it off as a loss and they replaced for him.
                                    Any tip or trick on where to start would be appreciated.
                                    Going to research the lines. Also going to disconnect...
                                    11-14-2023, 06:42 PM
                                  • howardc64
                                    by howardc64
                                    07-24-2025, 05:17 PM
                                  • x_orange90_x
                                    Samsung UN46C8000XFXZA Horizontal lines
                                    by x_orange90_x
                                    I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                    I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                    07-15-2023, 05:06 AM
                                  • mrsith
                                    Samsung UE70TU7100 - flickering horizontal lines
                                    by mrsith
                                    Hello again good souls.
                                    Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                                    I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                                    02-13-2023, 05:36 AM
