SONY KD-55AG8 DEAD
  • sordids999
    • May 2013
    • 2205
    • uk
    SONY KD-55AG8 DEAD
    Hi TV totally dead
    Main caps 570v reading 400v
    CN6401 pins
    1 TCON 12V 0 VOLTS
    2 BLL.ERR 0.6V
    3 EVDD ON
    4 ACOFF
    5 power on 0 volts
    6 stby 3.3v reading 3.48v
    7 - 13 gnd
    14-20 reg 12 reading 12.85v
    CN6601 pins
    1-6 TCON gnd
    7-12 12v reading 112v
    13-19 evdd-gnd
    20 nc
    Two fuses on TCON board
    65v 20 amp no reading not blown
    125v 10 amp reading 112v
  • sordids999
    • May 2013
    • 2205
    • uk
    More info
    While watching it made a high pitched noise and a sparkling pattern came on the screen then shut down.
    • Diah
      • Feb 2013
      • 6763
      Originally posted by sordids999
      More info
      so its not dead,,,, disconnect only EVDD socket on T-CON, turn on, check the Audio Optic on the MB lit red and remain red..
      • sordids999
        • May 2013
        • 2205
        • uk
        No nothing lit up red
        • sordids999
          • May 2013
          • 2205
          • uk
          RUN POWER BOARDS as Stand alone ....
          make bridge with R value 100 to 1K Ohm ( if the STBY 3.3V you can do it direct with out R but need to be sure 100% of the pins label )
          A- STBY & Power_ON ( this will turn on REG12V ON )
          B- STBY & TCON_12_ON ( this will turn on TCON_12V ON )
          C- STBY & EVDD_ON ( this will turn on EVDD V On Max 24V )
          Tried A voltage good
          But B and C no voltages
          • Diah
            • Feb 2013
            • 6763
            MB must be disconnected from PSU, and the 2 LVDS between MB and T-CON disconnected too
            • sordids999
              • May 2013
              • 2205
              • uk
              Yes done that
              • Diah
                • Feb 2013
                • 6763
                then remove yours Jumpers, connect every socket in place, just disconnected ONLY the lower ( 51 Pin ) LVDS cable from MB side, turn on and check the Optic port
                • sordids999
                  • May 2013
                  • 2205
                  • uk
                  Nothing lit up on the optic port
                  • sordids999
                    • May 2013
                    • 2205
                    • uk
                    Do you think PSU fault ?
                    • Diah
                      • Feb 2013
                      • 6763
                      if you did the PSU test as stand alone, and no T-CON 12 or EVDD then some things wrong with PSU for more info
                      Pin 6 STBY 3.3V , this should be connected to Pin 5 & 3 & 1 same time.
                      • sordids999
                        • May 2013
                        • 2205
                        • uk
                        Update
                        If I keep pressing the power button on the back proberly 15 times the TV comes on but loads up then shuts back down
                          Back Again?
                          • 32842
                          You see the 'Sony' logo? Sounds like a main board issue. Any artifacts visible on the panel when the problem occurs?
                          For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
                          Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
                          • sordids999
                            • May 2013
                            • 2205
                            • uk
                            Yes Tom
                            the Sony logo goes through the process on screen then the menu loads but shutdowns again but I can't get it to turn on again until the next day very strange fault
                              Back Again?
                              • 32842
                              I would say very likely to be a main board fault. I'd go old school. Get a hair dryer out and warm up the main board. See if it boots up reliably if you do that. Then try putting it in the freezer (but be careful to avoid condensation forming). Chances are the flash memory has become temperature sensitive due to bad cells.
                              If that confirms the fault you have two options, one is to try to reflash firmware (but might crash before it completes), or the other is to replace the board -- assuming you don't feel keen changing the eMMC BGA chip yourself, which is not an easy job unless you've done BGA work before.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4889
                                • Italy - Milan
                                Putting board inside freezer needs a plastic bag around it..
                                • cheeky2
                                  Sony KD-43XG8196 and KD-49XG8196 can the same motherboards be used as they use the same TCON pcb and main boards?
                                  by cheeky2
                                  I have a Sony KD-49XG8196 that I am hoping a Sony KD-43XG8196 main board will resolve my issues with the TV. The TV's both use the same TCON pcb board a 6870C-0761A and use the same main board model (1-982-626-41). Now will I have to modify the eeprom on the TCON board for the Sony 49inch screen TV to work with the TV as it thinks its a 43inch screen and may not communicate properly with the TCON?
                                  If I do what bits will I have to change in the eeprom? I am guessing the model number of the TCON board?
                                  Thanks in advance for any help in my quest to get this TV operational again.
                                  05-25-2026, 02:45 AM
                                • Daren87
                                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                  by Daren87
                                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                  08-13-2023, 03:25 PM
                                • iglitare
                                  Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                  by iglitare
                                  i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                  Backlight seems to work, Sound (Setup menu after reset) works.
                                  If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                  Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                  With my small knowledge i would think at least the cables are good.
                                  Can this happen because of a bad tcon board?
                                  Or is it always a bad/shorted...
                                  09-04-2025, 07:13 AM
                                • Chrissy-haras
                                  Looking for a sony KD-75XG8096 tcon board
                                  by Chrissy-haras
                                  Hi all
                                  im Looking for a sony KD-75XG8096 tcon board , i have backlights but no picture, ive uploaded photos for the model number. Thanks for your time...
                                  04-12-2026, 03:26 PM
                                • Yanleb
                                  Sony XBR-55X810C GN1T Chassis dead in the water, no white or flashing LED
                                  by Yanleb
                                  Hi, I have this Sony XBR-55X810C that was working when it was last used. It has been stored with the power cord disconnected for two years. Now, reconnecting the power cord it shows nothing. No white power LED, no flashing LED. It is dead in the water.
                                  On the power supply, the STBY3.3V standby voltage is OK. The POWER_ON has 3.4V and the power supply turns on, supplying 12V to the main board. This is pretty strange.
                                  On the 1-894-595-12 (A2072598B) main board, I did follow the troubleshooting section 3-2-2. NO POWER-U-Com Failure for no power, and the only abnormality...
                                  11-30-2025, 11:34 PM
