Got this one connect box 65QN95B and power supply is faulty and it’s faintly constantly clicking, the voltage that says standby 7.6v is not stable and going up and down, IC labelled 6b22 is getting very hot which normally fails on Samsungs but even after replacing it still same getting hot, the 4 resistors in the picture also getting hot but all read ok in circuit and out of circuit, them are the components getting very hot but not actually faulty and no short circuit anywhere and fuses ok, kind of stuck where to check next, I’ve included pictures of board and parts getting hot, all parts around the IC also seem to be good
Got 65QN95A one connect box power supply that’s faulty and clicking
It’s jumping between 10-12 v and once or twice went to 14v, the IC is at 70c and resistors at around 55c, relay is clicking on and off faintly, there’s no short circuits anywhere but can’t figure out what’s causing the components to get so hot
i wrote inside the OCB, you have it,,, doesent matter on the green or red boards... this is OCB firmware start... check Pin 8 if it had 3.3V... then on the other boards out put socket you have PS_PN feed it with this 3.3V, the OCB will start as stand alone to check the VCC of 350 and otherComment
This ic drives a pair of mosfets that drive a transformer, this transformer has a secondary that provides the run vcc for this ic, It may be as simple as the run electrolytic cap is bad, it is usually a small cap 47~100µf 50v and be near that circuit. it might be cp807? the small electrolytic with the white silicone around it.
If you follow the trace from pin 10 it should lead to an electrolytic, this point is supplied by the secondary winding on the transformer, through a diode and maybe a transistor as well that acts as a regulator. The samsung BN44-807A schematic might be similar as it uses the fA6B22 as well.Comment
Ok no problem, the confusion was when I mentioned mainboard you said no but now I understand thanks
Thanks I’ll take a look, I’ve repaired lots of Samsung oled boards that use that IC and one connects but never saw this IC heat up to 70c and replacing it don’t fix it, now I just got power supply from oled tv doing the exact same and exact same fault, so I got 2 boards now with exact same faints, 1 from a box other from a tv
Then caps are good, I checked a few more caps blue ones but even they are good, kind of stuck now on what can cause IC to get that hot without a short, I’ll try uploading thermal cam image
Thanks I’ll take a look, I’ve repaired lots of Samsung oled boards that use that IC and one connects but never saw this IC heat up to 70c and replacing it don’t fix it, now I just got power supply from oled tv doing the exact same and exact same fault, so I got 2 boards now with exact same faints, 1 from a box other from a tvComment
Assuming...7 Photos -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by AkuankaHi everyone,
I'm troubleshooting a power supply issue with a Sony SLV-E780 VCR. The device clicks repeatedly but doesn't power up completely. I've already replaced five capacitors, but the problem persists.
Here's a video link https://photos.app.goo.gl/3Xki6yvCLn67gLX78 showcasing the sound. Based on your experience, could this be due to a transformer, diode, or another component? Any guidance on what to test or replace next would be greatly appreciated.
Thanks in advance for your help! -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
