Samsung UE49MU6400 - unresponsive TV, flashing LED backlight
  • starlinghouse
    • Oct 2026
    Hi folks,
    Neighbour's Samsung smart TV went unresponsive yesterday. It setup is Edge-LED + LCD matrix. When plugged in to the wall, the screen LED backlight flashes every second. No response to on/off button or the remote. We did routine checks already, unplugging the TV from the wall, draining the caps, detaching all devices, etc.
    I studied some threads and youtube vids for how to troubleshoot. Here are the test results:
    - Unplugging the power board to main board cable doesn't stop the backlight flashing. See first photo and first part of attached video.
    - Flashing stops when we unplug the cable from the Power Board from the LED strips. Located on the power board's right edge, this cable/connector is labelled CNL802 and has four wires numbered 1+, 1-, 2+ and 2- so I think it tests the current through the LEDs. See the second photo and end of the video. With that cable unplugged, the 13V-labelled pins of the Power-to-Main board cable connector now test correctly, all giving a stable 12.8 V. Also, the on/off power button on the TV now comes to life to show a red light and responds to the remote control. Of course, with the LED cable disconnected, the screen shows no image.
    From these tests, I gather the Power Board works fine, but the LED strip has gone and needs replacement.
    Does this sound right? Any suggestions to help me ascertain that the fault lies with the LED, and not the power board? Any further ideas?
    Cheers,
    Andy
    Two photo and a video of the test
    Click image for larger version  Name:	Photo_A.jpg Views:	8 Size:	369.7 KB ID:	3957910
    Click image for larger version  Name:	Photo_B.jpg Views:	4 Size:	348.4 KB ID:	3957911
  • yokoono
    • Apr 2010
    • 570
    That’s a lot of words for a simple initial test: disconnect the cable leading to the motherboard and see if the backlight turns on and stays on. If the LEDs don’t light up, it’s almost certain that the LED strips are faulty (the plastic diffuser might also be melted). If the backlight does turn on, you then proceed to test the motherboard, the T-CON board (if present), and the panel.
    • starlinghouse
      • Oct 2026
      Thank you, for this crisp description of the test sequence. I am looking into this kind of TV for the first time.
      • Boardview and Schematic Bot
        Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Boardview
        Samsung Galaxy Tab S / E SM-T805W SM-T800 SM-T378V SM-T805W Schematic & Board View
        Samsung Galaxy Tab S 10.5 SM-T805W.sch.pdf
        Samsung Galaxy Tab S 10.5 SM-T800.pdf
        Samsung Galaxy Tab E 8.0 SM-T378V.pdf
        Samsung Galaxy Tab S 10.5 SM-T805W.bv.pdf...
        09-29-2026, 10:33 AM
        09-07-2024, 05:50 AM
      • learnmore
        Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
        by learnmore
        Hello Community!
        CASE DETAILS
        Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
        13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
        Tried inserting firmware on USB and left it in for a few hours, but no change
        03-03-2024, 09:49 AM
      • signal.quest
        Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
        by signal.quest
        I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
        I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
        09-30-2024, 11:21 PM
      • alro7779
        Samsung UN70TU7000FXZX A two-times flashing standby light loop with no image.
        by alro7779
        Hello, everyone!
        A friend of mine gave me a 70" Samsung TV that does not show image after pressing the power button... It's in a loop with the standby red light flashing two times while the TV tries to power on with a startup sound. You see, it occurs to me that I could try keep learning how to repair TVs out of this device, so I'll share some pics I took after taking the back cover out; I noticed that someone tried to repair it (or did it at some point) because I found a small power supply glued on the metal cover by the mainboard (3.3v IN and 13v OUT). The idea here is checking...
        04-03-2026, 01:26 PM
