i recently got this monitor second hand for a good price(no warranty or something),i used it till 511hrs and one time i leaved it on to eat something and when i was back i found it like this and i tried all the stuff (reset it,changing cables,changing computers,trying to update it(the newest version in both apps it s v1.01).I have CH341a if someone is willing to send me a dump or something.I attach my .bin.
Philips EVNIA 49m2c8900/00 white screen
by tech9pcHisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem. 2025 Model only about 1yr old. Puzzling because everything works except whited out screen barely visible picture. Screen is not cracked. Any ideas / suggestions? Would this be a all in one mainboard problem or is the screen failed. When on can barely see the image on screen, connects to WiFi and everything. Took back off and mainboard looks clean and new, reseated cables. Tried resetting the system to factory and it is the latest update May 2026. I researched this model online and apparently in the last 12 months about 2 out of...
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by usmantemuriI have a 55-inch TCL TV with a T-Con board model ST5461D04-1-C-7.
I saw on the internet that if one of the panel ribbon cables is disconnected, the TV may display half of the screen. However, in my case, when I disconnect either ribbon cable, that side of the screen turns completely white. The same thing happens on the other side as well.
There is no picture at all—only a white screen appears when either ribbon cable is removed.
...08-01-2026, 04:47 AM -
for this monitor flatron 575lm when i switch on i have a white screen...
When i connect the vga cable, i have an oscillating white screen, white 2 seconds and then nothing...it doesn't work.
I measured all the voltages on the main board and apparently all was ok...the processor is warming a little...
i have only a multimeter as measuring tools; but no scope. if it needs to program the eeprom i have a ch341a mini programmer.
Is there somebody who could indicate me the manipulations that i could operate to try to solve this problem?
Thank you in advance...-
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... - Loading...
