Sony KDL-46V4100 washed-out picture – bad gamma on FS_HBC2LV2.4 (K2204G). Will a 40" or 52" T-con work?
  • matthewmacias
    • Oct 2026
    • 5
    My 46" KDL-46V4100 has a washed-out, low-contrast picture, including the TV’s own menus. The backlight works and self-diagnostics are clean.
    T-con is FS_HBC2LV2.4, sticker K2204G8E0PTJ (LJ94-02204G). Readings: VIN, VDD, and VCC are good, AVDD 15.31V, VOFF −7.65V, VON in range.
    Gamma: VGMA1–9 are all stuck at 15.0–15.3V. VGMA10–18 read 14.39, 11.39, 11.02, 10.21, 8.65, 6.87, 4.9, 1.9, 0.24. This leads me to believe the gamma chip is bad.
    A 2204G is not available in the US right now. Two FS_HBC2LV2.4 boards are available from US sellers on eBay: a 2221K from a 52" KDL-52S4100, and a 02275E from a 40" KDL-40S4100. Would either of these work on my 46" panel, and if so, which would be the closer match considering they don't match my 2204G short model number? Or would waiting 3 weeks for an alleged 2204G from a Chinese seller be the better move?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    Yes it's gamma correction ic, the ISL intersil ic 321 , if you have hot air, colophony and IPA alcool you can do a mix of them or a good flux and reflow for some minutes the ic
    • valvashon
      • Oct 2020
      • 129
      Some t-con boards were not proprietary like the one you need, being used in both Sony and Samsung models. My search for that number on eBay pulls up literally dozens of those boards; I'm sure they are all the same and you could use any one of them. I did a similar repair on an old Magnavox 32" I'm fond of. The t-con board was bad (bad gamma) and I bought the cheapest replacement board on eBay and it works just fine. I believe that the auction had it tagged as a Samsung board.
      Val
        Back Again?
        • 32841
        Agreed you only need to match the panel and t-con number, the exact model of TV is irrelevant, Sony used various panels in their TVs and in some cases changed mid production run so model number alone isn't guaranteed.
        For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
        Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • cheeky2
          Sony KD-43XG8196 and KD-49XG8196 can the same motherboards be used as they use the same TCON pcb and main boards?
          by cheeky2
          I have a Sony KD-49XG8196 that I am hoping a Sony KD-43XG8196 main board will resolve my issues with the TV. The TV's both use the same TCON pcb board a 6870C-0761A and use the same main board model (1-982-626-41). Now will I have to modify the eeprom on the TCON board for the Sony 49inch screen TV to work with the TV as it thinks its a 43inch screen and may not communicate properly with the TCON?
          If I do what bits will I have to change in the eeprom? I am guessing the model number of the TCON board?
          Thanks in advance for any help in my quest to get this TV operational again.
          05-25-2026, 02:45 AM
