LG OLED OLED55C9PTA - Mainboard swapped (65" to 55") - Need 55" SPI Flash Dump
  • fakarui
    • Dec 2025
    • 7
    • Malaysia
    I'm working on repairing a 55-inch LG OLED C9. I swapped in a replacement mainboard, but the donor board appears to be configured for a 65-inch panel, resulting in a panel size/timing mismatch.
    I used my CH341A programmer to dump the Winbond 25Q32JV SPI flash chip (oledc9-65.bin), which I’ve attached to this post.
    If anyone has a known-good 55" C9 SPI flash dump to share, or can guide me on editing the panel option bytes in my current dump, I’d really appreciate the help!
    Thanks in advance!
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    the configuration is not there
    • Diah
      • Feb 2013
      • 6763
      all parameters can be changed at service menu IN_START & E-Z ADJ, use service RC
      • fakarui
        • Dec 2025
        • 7
        • Malaysia
        currently unable to turn on the tv, can i still use the RC?
        https://www.youtube.com/watch?v=kjj7ZBrDeVk
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4889
          • Italy - Milan
          why you replaced the Main b.?
          • fakarui
            • Dec 2025
            • 7
            • Malaysia
            my original 55" mainboard had an issue with eARC, so I swapped it out with a scrap OLED C9 65" board I had lying around. after swap, I got a black screen/no display maybe due to a panel mismatch.
            for work around, I desoldered and swapped the BIOS chip from my original 55" board over to the 65" board. It actually worked perfectly after that—until an automatic firmware upgrade happened.
            I'm guessing the board's main system storage still thought it was a 65" model underneath, so when the update rolled through, it pushed a patch that overwrote or messed with the BIOS chip configuration.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              The serial flash does not contain system profile / configuration, only the standby software, that usually it's the same for all the series of that tv, what caused the set to display at second try i do not know, panels are not plug'n play i think, at least there are not service manuals that instruct this i think. The only thing to easy solve is to get the correct Ebt Ebr codes board
              • fakarui
                • Dec 2025
                • 7
                • Malaysia
                all right noted, thanks yea. do you have the bios file? this is my last attempt before buying a new tv.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4889
                  • Italy - Milan
                  i don't have, you does not trust me, your original mb has a problem of hdmi soldering maybe, a very stupid problem for a tv service to repair
                  • Diah
                    • Feb 2013
                    • 6763
                    with service remote press P.ONLY , check if it turn on
