Tv fix
  • Eduar larion
    • Oct 2026
    Tv fix
    I have a Samsung QE55Q6FNATXXU 55-inch QLED TV.
    The TV attempts to power on for 1–2 seconds, the red standby light flickers, and then it returns to standby. There is no picture, backlight or sound.
    There is also a repeating high-pitched buzzing/whining noise coming from the power supply transformer area, lasting approximately 13 seconds before briefly stopping and repeating.
    I've replaced the entire power supply board (BN44-00878C), but the symptoms remain identical.
    I also tried disconnecting both LCD ribbon cables from the mainboard, but the TV still wouldn't start.
    Mainboard: BN94-13028K PCB: BN41-02636A
    Does this suggest a faulty mainboard, or could the LCD panel still be causing the shutdown? Are there any known diagnostic tests for this particular model?
    I'd appreciate any advice before buying another motherboard.
    Back Again?
    • 32841
    Before firing the parts cannon at the TV, let's try to check if the power supply is working.
    Do you have access to a multimeter and know how to use it?
    Please post clear pictures of your main board and power supply board.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • Jembang
      coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
      by Jembang
      good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
      11-01-2024, 09:55 AM
      03-31-2024, 02:12 PM
    • stylishconsultant
      un60j620dafxza - Samsung No Display Problem
      by stylishconsultant
      Hi All,
      Need help.
      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
      09-04-2024, 03:26 AM
    • Yanleb
      UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
      by Yanleb
      My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
      Disconnecting the main board from the power supply makes the backlight come ON.
      I did disconnect the panel cables and the WIFI modules, the board is still dead.
      I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
      Thanks.
      11-18-2024, 12:34 AM
    • xbliu.cn@gmail.com
      ASUS ROG Zephyrus G14 GA402R – 19V present but no 3.3V/5V standby, no power
      by xbliu.cn@gmail.com
      I’m looking for help diagnosing a no-power issue on an ASUS ROG Zephyrus G14 (GA402R / GA402RK series). ❗ Problem
      The laptop does not power on at all:
      • No LEDs
      • No fan spin
      • No response to power button
      The issue started right after a RAM upgrade. The previous owner mentioned there may have been static discharge during reassembly.
      🔍 What I have checked so far (with a multimeter)
      • AC adapter is confirmed working
      • 19–20V is present at the DC jack
      • Both input MOSFETs have 19–20V on both sides
      • Multiple inductors near the eDP connector
      12-13-2025, 11:40 PM
