Need photos of the main board of an LG 42LD490 please
  • Ady2017
    • Dec 2017
    • 57
    While re-flowing the solder on the main board of my LG 42LD490 TV a couple of small chips came loose and I am now struggling to work out which one went where. I desperately need some photos of the underside of the main board and especially close ups of IC8401 and IC9000. The loose chips have got the markings 402N and 35331 on them but it still does not help work out which one went where.
  • Ady2017
    • Dec 2017
    • 57
    Please delete my post above. I managed to get a service manual and have now resolved the situation.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • tvguy12012012120
      Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
      by tvguy12012012120
      I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
      Any ideas as to what would cause these symptoms?
      Symptoms:
      • From cold power-on, picture is perfect.
      • After ~2–3 minutes, the image slowly degrades:
        • contrast collapses
        • colors wash out / look incorrect (greens especially bad)
        • image looks “milky” / flat
      • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
      • Internal
      01-07-2026, 03:30 PM
    • frannyjunk
      Onn model 100012585 main board transistor is blown
      by frannyjunk
      I am a relative novice when it comes to electronics. I am in the process of fixing a 50” Onn tv. No voltage getting to t-con board (V12, VGH, VCON all reading near zero). On closer inspection, the transistor (on the main board) close to the LDVS socket looks to have blown. I am assuming that replacing this transistor will get the tv going again. Question is, how do I get the transistor part number?
      09-07-2026, 03:41 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
