SONY KD-65X85L
  • dimis7
    • Feb 2011
    • 30
    SONY KD-65X85L
    I have a SONY KD-65X85L with backlight an possibly main board issues.
    Does anyone have the service manual for this set?
    Symptom was: display start with backlight on and sony logo, after few seconds sony logo disappear and TV remain dark (backlight on). Put it in stby with remote, then back on with remote and backlight not start again.
    Fiddling around with connectors etc and now the backlight never come on again. But i can see the sony logo with a flashlight.
    One time i manage to reset it and i saw the android set-up wizard (with backlight off) but i can't replicate it.
    On LD-Board there are 2 leds. 1 yellow and 1 red. Yellow blink once on startup and red blinking 3 times, pause, 3 times again, pause etc
    Boards:
    PSU: AC21552 from BAH PI ELECTRONICS
    Main: BM5A23 / 101697451 / A5056809A
    LD-Board: 23LD32A / 101618311 / 101618211 / A5052312A
    TCON: can't see the p/n without further disassembly.
    Voltages on PSU with TV on and backlight in a non-working state:
    VLED_VCC: 19.7v (with or without LD-Board connected)
    VLED_GND: 0v
    SENSE_GND: 0v
    GL_CTRL: 2.1 - 2.5v
    12v(LD): 12.5v
    BL_ON: 2.9v
    BL_ERR: 0v
    POWER_ON: 3.2v
    STBY3.3v: 3.3v
    REG12V: 12.5v
    TCON_ON: 3.3v
    TCON_12V: 12.5v
    The backlight stopped working when i disconnect and measure the GL_CTRL line. I was trying to understand if it's input or output from PSU. Never shorted or anything like this. Maybe it was coincidence.
    (it is input btw)
    No have any error codes on the front led, and tv seems that responding to remote commands.
    (need about 1 minute to boot i guess when i plug it in the mains power)
    Any ideas are welcome!
    Thank you.
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    Post a picture of the whole back of tv set, read first my sticky post
    maybe this set is a local dimming one
    • dimis7
      • Feb 2011
      • 30
      I will take some photos later and upload it.
      And yes it's a local dimming set.
      Did a test yesterday. I disconnect the VLED_VCC rail from PSU and inject 24v from external power supply.
      Backlight is now working and on LD board i get steady yellow led when backlight was on and no red led.
      Problem is that i manage to get to android setup wizard (with backlight this time) only twice out of 30 - 40 restarts.
      While i was there, i finish the android set-up and the last step was a "Bravia tv experience" set-up something like that. I guess is the portion of the set-up where the tv will scan for channels etc.
      This was completely corrupted. The background was there but all text and buttons was missing. can't do anything other to go back to initial set-up steps.
      Restart tv and got black screen again.
      Also i try to upgrade / reinstall the firmware. I download the zip file from sony and extract the 2 files on the root of a usb stick. When i insert the usb i got a message that the device is not suitable for the firmware update (but i was inside the set-up, so this could be the problem).
      Tried with 8GB and 64GB sticks, FAT32 and NTFS filesystems.
      So main board have for sure some kind of problem, and probably is not sending the command to wake up the psu? or both main and psu are faulty.
      Maybe the problem is with eMMC and reads corrupted data i don't know...
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4889
        • Italy - Milan
        Where do you read about the correct voltage of 24v instead of 19? How many years has the tv? Since the PSB is not providing the correct V to the LD i would first trouble shoot the PSB before condemn the other one, since it has a oscillating behaviour this is not much in line with cracked balls.. or at least with cracked balls you would have a better behaviour at cold and never get it working at warm
        • dimis7
          • Feb 2011
          • 30
          i was lucky and able to measure the voltage before backlight dies completely and it was 24v, so i risk it...
          i take the TV from a friend and he told me it's 3 years old
          I found a local set with broken panel but is 75" not 65", main should be the same but not PSU.
          It's only 70euro so i'm thinking to take it and ,according to seller, TV has 0 hours.
          A used / refurbished main board will cost me the same or maybe more.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4889
            • Italy - Milan
            Nooo, i do not suggest it to you, 3 y. old is too young for emmc / cpu / ram problems i guess, my opinion that you have a conclamated fault at power board that provides few volts to the backlight, that board must be repaired first, then you can judge, bye
            • dimis7
              • Feb 2011
              • 30
              Sorry didn't have time to take the pictures yet...
              Yes power supply seems faulty also, but mainboard only takes 12v to work, and 12v is ok.
              I dont understand why when it boots the menus are corrupted, but the 12v rail is ok.
              Anyway i take the 75" set... Will swap the main and will see... Also power supply from 75" should be compatible, but it's very big to fit in the chassis. Worth check the voltages before remove anything from the 75" set. And it's really new, 0 hours. I was broken by the shipping company that take the set to the customer.
              • dimis7
                • Feb 2011
                • 30
                Some pictures from individual boards...
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4889
                  • Italy - Milan
                  Ok well done with the photos, now seeing the Power board (PSB) i can see 3 transforners and a big coil on the secondary part, what i think is that the small one is for 3,3 v standby supply and is probablly ok, the big ones are for a twin 12v output, but one serves the main board and one the booster (with big coil) that feeds with 24v the LD, so i don't know who feeds the tcon, if the tcon (probably not) is fed by he faulty 12v rail with low voltage then the tcon can work bad and image can show bad, who knows, i think you don't want to repair at component level but i would not take a tv only for main board. Stop.
                  • dimis7
                    • Feb 2011
                    • 30
                    The top right heat sink and the 2 capacitors below are for the 24v rail.
                    Re t-con, if i disconnect it from main, it's going to a self-test mode, where red, green, blue and a chess like pattern is generated. This works every time.
                    When is connected to main, only 1 out of 40 times i get an image, and it's not always corrupted. For example i manage to complete all steps on Android tv setup wizard (set language, region, connect to wifi, connect to my google account) without any problems. Once finish this and start the "Bravia tv experience" i get the basic layout of the menu, but without any text and buttons.
                    Pressing the "back" button on remote take me back to Android tv setup steps, where all elements was visible again.
                    Now that i have a working main i can isolate the problem. If there is a problem on PSU, i would like to repair it at component level if possible.
                    Im good with soldering iron and comfortable to work with smd components (but not BGA since don't have the tools for that).
                    Problem is that there are no schematics and i guess i psu that gives 19.5v instead of 24v will be difficult to troubleshoot.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4889
                      • Italy - Milan
                      Further note, when buying Sony main boards you must match the codes on the QR code not only the copper code
                      post a photo of the entire back of the tv with boards, and also check the model code, i do not find another discussion for this model
                      • dimis7
                        • Feb 2011
                        • 30
                        TV is working again. I swapped the main from 75", then from service menu i switch to the correct model (65"). Only problem is i can't change the S/N (the option is grayed out) but i don't care abt that.
                        Re PSU the fault was with the cable that connects PSU with LD-Board. I took the cable also from 75", it's little longer but will do the job.
                        Funny enough, i can't find anything wrong with the original cable, so I'm glad that i took the other set after all.
                        Any ideas how to take the panel calibration data from the old board and transfer to the new one? I found an option to transfer the data from t-con to main, but I'm not sure if i did it correctly or if the data was in the t-con in the first place, since all values are set to 512
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4889
                          • Italy - Milan
                          5v lost in a 50cm cable? How can it happen? anyway it's a common bga issue then.. you better protect the new board other wise you'll see a new downfall soon or later
                          • dimis7
                            • Feb 2011
                            • 30
                            Not lost... for some reason psu does not fully start with the original cable.
                            What do you mean to "protect the new board"? How to do that?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4889
                              • Italy - Milan
                              no, sorry, every time i say it nobody does it, so do not care about
                              • dimis7
                                • Feb 2011
                                • 30
                                I don't plan to replace the main again, so I'm curious, how to protect the new board? Put a UPS on TV?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4889
                                  • Italy - Milan
                                  a little bit of hot glue around bga chips, seal the perimeter perfectly.
                                  • Random Bloke
                                    • Sep 2026
                                    • 8
                                    They dont need sealing though. BGA fail from thermal expansion and contractions not dust.
                                    Applying hot glue offers zero protection.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4889
                                      • Italy - Milan
                                      Dimis, now you know why i hate to repeat my trust, every time debates and criticism.. i'm very stew of this site..
                                      • dimis7
                                        • Feb 2011
                                        • 30
                                        I don't think it will do any harm, so i did it anyway.
                                        + it's very easy to remove hot glue from pcb with a drop of alcohol if needed.
                                        Hope will last few years more
                                        • NXTPRO
                                          Sony Bravia KD-55X8000G stuck at Sony Logo
                                          by NXTPRO
                                          My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
                                          Board: 1-982-454-51
                                          04-03-2026, 07:28 PM
                                        • jbaranas
                                          Sony KD-55X8000C - No picture, shows Sony Logo but blue screen after
                                          by jbaranas
                                          Hello Everyone!
                                          i am having trouble with my TV, my friend gave it to me and he told me he got it from somewhere so that is why I did not know the history of it.
                                          When turning on, it shows Sony Logo, then solid blue screen after. Then nothing just stay that way.
                                          I bought Main Board from ebay then T-Con from Aliexpress. Replaced Main board, the TV improved it is like booting up to dashboard, then I put on my chromecast and I try to play youtube videos with it but no picture. I then try remove LDVS from old t-con, then it asks for update showing green and orange...
                                          06-11-2026, 01:39 AM
                                        • hardwareserwis
                                          Asus Strix G513QR logo appears, then only the backlight stays on
                                          by hardwareserwis
                                          Asus Strix G513QR-HF016
                                          Motherboard: G533-MP-GBM, 6050A3250202-MB-A01
                                          The motherboard powers on, the Strix logo appears, then only the backlight stays on — it does not enter the BIOS and hangs at that stage.
                                          The laptop arrived with a broken screen and a damaged display cable.
                                          Actions performed:
                                          • New BIOS dumps have been flashed
                                          • A new Ryzen 7 CPU was soldered in (tested with two different units), but the issue remains the same with both
                                          • Tested with a different display cable and screen
                                          • No missing components or visible damage on the motherboard; no components
                                          09-29-2025, 01:02 PM
                                        • JohnML1975
                                          Sony KD-75X7800F - has backlight but no picture
                                          by JohnML1975
                                          Hello
                                          Started working on this TV
                                          Backlight is working
                                          There is no picture
                                          The backlight changes with what I would assume is the TV boot up sequence
                                          I disconnected the two cables between T-CON and mainboard
                                          Problem remains the same
                                          Next I will remove the speakers and the metal panel covering the buffer boards at the bottom
                                          Then see if I can break the problem down further...
                                          12-31-2025, 02:17 PM
                                        • JohnML1975
                                          Sony KD-55X8500F starts, shows logo, shuts down, six blink error code
                                          by JohnML1975
                                          Hello All
                                          Started working on this TV today
                                          Will share a video of the problem soon
                                          Problem
                                          I press ON
                                          Can hear TV click
                                          Screen lights up
                                          Logo starts to run
                                          TV screen flashes
                                          TV shuts down
                                          Standby light shows a six blink code using red light
                                          I have to remove mains power
                                          Then start over again
                                          Will remove back of TV and have a look inside
                                          09-19-2026, 09:57 PM
