Panasonic plasma no picture
  • nervx
    • Oct 2014
    • 17
    TC-P46G10
    Tv was running, left the room and when I returned the screen was black. Audio could still be heard. Turning off and on the tv you can see the panel adjust black level so it seems to be getting power. No tv menus show on screen when trying to bring them up. There is also no error blink code. Checked inside and couldn’t find any bad caps or burn marks. The LEDs on the s boards are both green which I assume means good.
    trouble shooting guide says A-board is at fault but I want to know if anyone has encountered this and any solutions.
    Hard to put money into a tv this old but also want planning to buy a new tv until maybe next year.
    Back Again?
    • 32841
    Try the following
    Press VOL- on TV and press INFO three times on remote
    Wait 10 seconds
    Press number 1 button on remote four times
    Press number 3/4 to cycle through test patterns
    Do you see test patterns?
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • nervx
      • Oct 2014
      • 17
      Originally posted by tom66
      Try the following
      Wait 10 seconds
      Nope nothing
        Back Again?
        • 32841
        Ok, I'm reasonably sure the problem is with the A board, given what you've described so far. I don't think it could be repaired, you would want to replace the whole board.
        • stecos
          Is it possible to convert the Panasonic plasma TNPH0988 motherboard from a TX-P50VT50T to a TX-P65VT50T?
          by stecos
          Hello everyone, I'm back with a question about a type of TV I'm passionate about: Panasonic plasma TVs!
          I have a TX-P50VT50T that's in perfect working order and a TX-P65VT50T that's showing no signs of life.
          I'd like to "sacrifice" the 50-inch to bring the 65-inch to life.
          From my analysis, the non-functioning board on the 65-inch is the "A" mainboard, which is unobtainable.
          Therefore, I'd like to install the one from the 50-inch.
          What IC changes would I need to make? Has anyone already converted this TNPH0988 for different...
          06-01-2026, 09:02 AM
        • dom.true
          IC2960 for A Board - Panasonic TH-P42X10Z Plasma Television
          by dom.true
          Hi Folks,
          I have a Panasonic TH-P42X10Z Plasma Television (2009-era; New Zealand model).
          This set has proven to be extremely reliable throughout its +16-year lifespan. However, late last year, when going to use the TV, I noticed a 9-blink red LED error code on the front of the set after the television failed to turn on. A quick Google search revealed that this indicates a problem with the set’s main A-board.
          After opening up the set and giving the board a thorough test with my digital multimeter, I found that one of the integrated circuits on the board...
          01-17-2026, 05:01 PM
        • jm1234
          Panasonic plasma TX-P42ST50 - 6 blinks
          by jm1234
          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
          I checked that board for any obvious faults...
          05-22-2024, 06:59 AM
        • KYBOSH
          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
          by KYBOSH
          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
          No picture but you hear the TV static (white noise) playing loud and clear.
          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
          But it seems they didn't get too far and just left it.
          When I first took a look I was amazed at how pristine the inside looked.
          Its as if the TV had been in a time capsule.
          Caps looked like they were just pulled off the self.
          Copper coils had no sign of corrosion on...
          02-01-2023, 11:10 PM
        • stecos
          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
          by stecos
          Hi everyone!
          I happened several times, in the search for help from the web, to consult this very interesting forum.
          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
          Having said that I come to the gist of my post on the forum as the title suggests.
          For my passion for technology I'm now collecting several...
          11-28-2022, 11:39 AM
